Mar 06, 2012, 10:14 PM
"Five Easy Pieces"
Monday's Sortie.
F-14 TOMCAT Rebuilt.mov (6 min 48 sec)
Mar 07, 2012, 09:18 PM
"Five Easy Pieces"
Only worked a 1/2 day at my new job today so I came home and video'd my Five Easy Piece F-14 TOMCAT build sequence. Included is my new "Elevons-On-A-Stick" method for the F-14, F-15 and soon to be rendered F-18 planes.
F-14 TOMCAT "Five Easy Piece" BUILD.mov (19 min 25 sec)
Mar 08, 2012, 04:57 PM
bsfixit's Avatar
Thanks for the vid, I need to cut out another KFm strip, for some reason I was thinking of only one KFm strip. I do not think it will matter much with the motor I have in mind... but it will make inversion flying possible...with both strips ..
Mar 08, 2012, 05:01 PM
"Five Easy Pieces"
You are very welcome.
I'm glad it helped.
Now I wanna see pics and vids of you flying the TOMCAT.
Mar 08, 2012, 08:54 PM
bsfixit's Avatar
I'm glad it helped.
I am trying to find my micro balloons to fill some voids that resulted from me not cutting out of the parts exactly right. And I have to put some camouflage or better yet, plain grey paint airbrushed on.. I would also like to stiffen the nose LE and vertical stabs with some real aircraft fabric. much lighter than fiberglass.
I have a question about thrust angle of the motor/prop.. If tractor setup is down and to the right. is a pusher up and to the left? I do not have a lot of experience building pushers... except one spaFFFnutz flying wing, which I think is neutral in the thrust angle.
Mar 08, 2012, 10:13 PM
"Five Easy Pieces"
You want to be totally neutral on the thrust angle. you want it straight down the centerline of the main wing.
May I suggest that you just toss the F-14 in the air and get the feel of the plane. Then build your second one better with paint, etc.
Mar 09, 2012, 09:25 AM
bsfixit's Avatar
Thanks for the info on thrust angle. I am going to get some work done on it today, I will post up a video, either from the plane or from the ground view. It is just a matter of when the winds will cooperate down here in Florida.
Apr 08, 2012, 11:12 PM
"Five Easy Pieces"
Another romp with the Tomcat.
F-14 Tomcat Sunday (6 min 50 sec)
Apr 08, 2012, 11:14 PM
"Five Easy Pieces"
Sunset fligt of my five easy piece F-14 Tomcat
F-14 TOMCAT's Sunset Spin.mov (5 min 31 sec)
Apr 09, 2012, 08:19 AM
"Five Easy Pieces"
More sorties with my Tomcat
Tomcat's Prowl.mov (2 min 52 sec)
Apr 14, 2012, 09:13 AM
"Five Easy Pieces"
Clear blue skies calm winds.....you know where I'm going with this.
Five Easy Piece F-14 Tomcat Sortie.mov (6 min 5 sec)
Apr 14, 2012, 10:14 AM
bsfixit's Avatar
I did some work on my F14, but got side tracked by a .60 stroke nitro to electric conversion.. and recovering the wing with Koverall. The scraps of which will be used on the f-14 to strengthen some areas of the foam joints..
Apr 14, 2012, 11:03 AM
"Five Easy Pieces"
My whole build thing is sidetracked too as between work and helping my Babe get her house ready to sell there is no time to ponder.
I have build and flown two of my FEP F-14's now and I can tell you a weak point in crashes is a line parallel to the fuse and about an inch offset extending from the motor mount forward. The foam wants to split there upon a nose in type impact.
I didn't carry the KF airfoils over to the fuse because I liked the prototypical look of them stopping at the Nacelle line. I'm going to add a 12" piece of Carbon rod just behind the motor mount to stiffen this area. The Koverall might do the trick there too.
Apr 16, 2012, 07:59 PM
bsfixit's Avatar
The Koverall works great with a 5 minute epoxy, thanks for the tip, it won't add but a few grams here and there. This motor I plan to use for the F14 should make have it unlimited vertical !
Apr 17, 2012, 09:36 AM
"Five Easy Pieces"
You're welcome.
I have flown my F-14 with the Grayson hobby Micro-Jet v3, Super-Sonic v2 and the Super-Mega-Jet v2. I prefer the SMJv2. Although it does well with the SSv2 and a 7x5 prop.
Please post a video when you take her up.
Build Log GIANT 210% Jetset44 F-14 Tomcat wilmracer Pusher Prop Jet Models 300 Jun 26, 2017 10:39 AM
For Sale F 14 tomcat turbonut Aircraft - Electric - Jets (FS/W) 4 Jul 18, 2011 12:32 PM
Discussion Which F-14 Tomcat would you recommend? NeilDahl51 Electric Warbirds 3 Apr 22, 2011 12:15 PM
Discussion F-14 Tomcat scrappus Electric Ducted Fan Jet Talk 1 Mar 14, 2011 02:57 PM
