Unsticking a seized carb - RC Groups
Feb 22, 2012, 12:48 AM
I was pretty proud of myself in tearing down a seized TT gp42 and cleaning a 10 minute bench run years ago leaving a freely turning motor. (YouTube is great)
I am still very new to the hobby and this is my first attempt.
However the carb is seized solid. I have it soaking in the garage right now in fuel....(though it is very cold out there) will that do anything or do I need to rinse it and apply heat?
Or what is the best way to save it rather than buying a new one?
All advice is appreciated to get this motor back running
Steve
Feb 22, 2012, 01:51 AM
They don't seize unless damaged. It's just gummed up with oil. Soak it in fuel or alcohol and work it open and shut. It will free up.
Feb 22, 2012, 02:28 AM
You made that out of trees?
Boomerang1's Avatar
Put the carb in hot (not boiling) water for a while then try to move the barrel while it's still hot.
Don't forget to use gloves!
Once you have it apart, cleaned, dried & operating o.k. make sure you re oil it to prevent corrosion. - John.
Feb 22, 2012, 03:30 AM
Who Dat!
GeetarJoe's Avatar
I agree with datsunguy. It's most likely just gummed up oil. It can make it seem like its seized. Alcohol will work and so will heat. I've had luck with heating them up with a hair dryer.
Feb 22, 2012, 03:33 PM
Yup, heat is a good idea
Feb 22, 2012, 03:39 PM
Gluehand's Avatar
Heat the carb body with a cigarette lighter (remove any plastic parts first), and the gum will soften right away.....
Feb 22, 2012, 03:53 PM
Transplant in 1996
I am greatly influenced by the heat method, But have found in the last 2 weeks. Using my crock-pot/antifreeze method has worked the best. I have rebuilt 13 engines and flying 12 of them presently. That's when it gets above 50 degree's here in Nebraska.
Feb 22, 2012, 08:27 PM
DL8698's Avatar
If your carb is like that on my OS 35, then this is how I pulled my seized (gummed up) barrel out.
I put a few washers with internal diameter bigger than the outer diameter of the throttle barrel, such that the washer holes are over the barrel and the washers seat on the carb itself. On top of these I put in smaller washers that do not pass thru the large washer holes, but with with internal diameter smaller than the head of the throttle arm screw.
Then screw the throttle arm screw back in, and keep turning. The barrel slowly gets yanked out as you turn the screw tighter. It works a bit like a screw jack. As the barrel comes out, I keep adding washers and continue to screw the barrel out.
I did heat the carb a bit with a heat gun, not much, before doing this. Not sure if that contributed anything, but the barrel came out real easy.
Feb 23, 2012, 04:33 AM
Another for the crockpot method. It not only frees it up, but cleans it too. I just did this to an old OS .91 surpass that was on a swapmeet plane. Rebuilt and back in service.
Edwin
Feb 23, 2012, 08:43 AM
Thanks for the reply's.
I got home last night after leaving it sit in glow fuel for a day and nothing......
Figured since it was sitting in fuel, the next step I'd try is the hot water....(and then go the heat route after that) Tossed it in a pail of hot water.....no sooner than 30 seconds later I pulled it apart. It was gummed up beyond all belief.
Cleaned it up have it back together and it works...
One question I have about the crock pot method....what do most do with the antifreeze after a cooking? Can you pour it back into the container and use it again or proper disposal?
Steve
Feb 23, 2012, 08:55 AM
I use it 3 or 4 times then go to the recycler.
Edwin
Feb 23, 2012, 09:33 AM
Steve
I just leave it in the crockpot, turn the pot off and put the lid on. That way I am ready to go for the next application. You can not use the crockpot for anything else after putting anti freeze in it. Anti freeze is toxic.
Feb 23, 2012, 01:57 PM
Carb
Use a heat gun and some oil. Heat real good with prop on engine. Holding unto prop heat all the way round to whole carb. Shoot oil and move slowly. Unless damaged it will work free. Hair dryer will not get hot enough or hot water. Heat gun get hot and be careful. You had engine running before so its just gummed up. Lube carb inside and out any any part that moves.
Jun 03, 2017, 04:26 AM
The crazy Swede.....
wdac's Avatar
that worked good for me, thank you for sharing your experience with us even tho its 5 years later
Jun 03, 2017, 04:27 AM
wdac's Avatar
my GF hairdryer worked just fine 30min ago
Help! Brushless motor seems seized up???? Cutlass69 Power Systems 3 Feb 09, 2012 06:43 AM
Question OWB seized onto main shaft - HELP! snoshoe62 Large Electric Helis 0 Oct 22, 2011 05:06 PM
Sold 'Heads Up RC' 4260-06 - seized gallfer Aircraft - Electric - Power Systems (FS/W) 1 Sep 12, 2011 12:33 PM
Unsticking SoLite...Is there an easy way? mars Parkflyers 3 Mar 06, 2003 12:04 PM
Unsticking the carb newflyer Electric Plane Talk 0 Jul 08, 2001 01:51 PM
