May 07, 2012, 05:44 PM
Originally Posted by freezywilly
samuelsonbm that charger says it is for a 11 volt battery. Use caution.
TonganSojah do yourself a faver and spend a bit more and get a good charger.
Saying batteries are cheap is fine but plan ahead to the future.
that charger is for both 7.4 and 11.1v, there is 2 conections 3 cells and 2 cells, 3 cells charge 1 A 2 cells charge 1.5 A. its safe to charge 2 cell batteries its designed for that
May 07, 2012, 06:34 PM
An others interesting motors to try:
Good motor, less kv means less RPM, but also, more torque so this is a good option with 11- 12t pinion (little main frame mod is needed)
https://www.hobbyking.com/hobbyking/s...tor_200w_.html
even better motor, more power (NO main frame mod is needed can use the stock pinion 2mm)
https://www.hobbyking.com/hobbyking/s...or_4200kv.html
good motor, could be the best option, this one is used in Honey bee king helicopter, to move a 27 cm wooden blades, 2.8 diameter need to check the frame space, pinion 10-12 (little main frame mod is needed)
https://www.hobbyking.com/hobbyking/s...eli_Motor.html
this one could bee to week, but if it has the strong enough for the main rotor, this one could give you more flight time
https://www.hobbyking.com/hobbyking/s...or_4500kv.html
moki155 suggest, interesting option shaft 2mm you can use the stock pinion so (NO main frame mod is needed)
https://www.hobbyking.com/hobbyking/s...er_4100kv.html
Powerfull motor! but could means less flight time, (little main frame mod is needed) a 3m pinion is needed 9-11t
https://www.hobbyking.com/hobbyking/s...er_5250kv.html
May 07, 2012, 06:50 PM
The mods sound interesting and I may do it to one of mine. However, I am looking at a CP heli (6 channel xmtr and RTF) for slightly more cost.
It is 450 size and has good dealer support.
May 08, 2012, 03:05 AM
markkona's Avatar
would love to try this mod so the Y connector is so you can connect the stock battery to the jst female connector in the F45 and to the ESC as well no?? have I understood the concept?? This will be my next mod when stock motor dies so I can enjoy 10minutes plus flight time without worry about the motor getting too hot and dying out when the heli is 150ft above my head
May 08, 2012, 03:51 AM
hey guys is this the same battery as the stock battery??
http://www.ebay.com/itm/DH-9101-7-4V...item19c3908fbc
May 08, 2012, 04:04 AM
markkona's Avatar
if you re going to buy that get this
http://www.ebay.com/itm/Battery-for-...#ht_2738wt_952
May 08, 2012, 04:22 AM
i was just looking around on ebay and found that so i was just curious if its the same battery. plus its only 100 miles away from me which is only 1 day shipping..
thanks for the info. hows your heli? mine is still great i had a major crash today and there was no damage just paint job
skip to the end for some crash lol
http://youtu.be/pJoNyx-Vmq8
markkona's Avatar
Just ordered the brushless esc and motor from Hobbyking so I'll be prepared when the main motor gives up only 30USD for the 2 items but will probably test it before the stock motor dies so I can compare them Will keep you guys posted when they are delivered!
May 08, 2012, 04:26 AM
still a lot to learn!!!!
Auflyer's Avatar
Seems to be a very confined space your flying in, could have been worse the pool could have been full
markkona's Avatar
If you had filled your pool you probably wouldn't have crashed Btw I think you should take off your landing training gear if you can hover and land it you don't need it for flying start making some circuits now
May 08, 2012, 04:31 AM
markkona's Avatar
Don't you think this is a better deal than the stock battery?? Slightly more power and cheaper when compared to price of stock battery on Ebay.
http://www.ebay.com/itm/290557214235...ht_2341wt_1185
May 08, 2012, 04:33 AM
hahaha and thats why you fly in a open field not by the pool hahaha. it was kinda windy so i didnt go to the local field, I'm waiting on my battery and a mini camera so i can go and let it go wild in the field. better then going only for 9 min then come home.
how long does the motor need before i swap battery? around 15-20 min?
May 08, 2012, 04:39 AM
yes i got 3 stock battery and 2 of this so i can just change up the jst plug
http://www.ebay.com/itm/7-4V-1500mAh...item3cb973b961
May 08, 2012, 05:27 AM
markkona's Avatar
I think you can fly it again as soon as motor feels cold to touch but I'd wait for the others the chime in with their opinions!! i ALSO WANTED TO ASK IF IT IS POSSIBLE TO LUBE THE MOTOR WITH SOME LIGHT MACHINE OIL SO IT DOESN'T GET SO HOT WITHOUT DOING MORE HARM THAN GOOD!!
May 08, 2012, 06:14 AM
Brent 黑雁
BThirsk's Avatar
NO. Machine oil will short the motor windings.
If you want lube, use a dialectic like wd40. It will improve performance, but reduce motor life. The proper way would be to disassemble the motor and grease the bushings.
Discussion On self stabilising single-rotor helis (FP/CP) and comparison to quadcopters and coax LMF5000 Electric Heli Talk 10 Apr 13, 2014 02:59 PM
Discussion UAV systems Single Rotor vs Multi Rotor iskoos UAV - Unmanned Aerial Vehicles 2 Jan 06, 2012 11:51 PM
Question Upgrading from Co-Axial to FP Single Rotor Judo JoNny Electric Heli Talk 57 Sep 20, 2010 12:10 PM
Discussion Best FP single rotor 4 CH Heli? helinewbie617 Micro Helis 76 Oct 31, 2009 07:16 PM
For Sale will trade my orbiter coaxial for a fp or cp single rotor heli micro heli Aircraft - Electric - Helis (FS/W) 3 Sep 05, 2007 01:36 PM
