Wrong Polarity alarm with TP/PQ adapter on 10x charger - RC Groups
Feb 18, 2012, 06:54 PM
Question
I just purchased a 10xp charger. It works fine charging 1 or 2 batteries of 2 or 3 cells with the GP/KO adapter. However whenever I try to use the TP/PQ adapters I get wrong polarity alarms. The alarms occur whether I am trying 1 or 2 channels on either 2 or3 cell packs of Hyperion, Polyquest or Maxamp batteries. I have tried each board on channel 1 alone and get the same results. The charger has connect mode set to FMA
What am I doing wrong?
Feb 20, 2012, 10:01 AM
Sindland MC SAA
Howard Matos's Avatar
Hi,
Sounds like you are connecting correct but to make sure, make sure the RJ1 pigtail is always connected to the charger, regardless of the side used TP or PQ. The RJ2 pigtail is only connected for 6S packs and then both pigtails are connected to the charger, RJ1 to channel 1 and RJ2 to channel 2. If you have a multi meter, check each pin starting at the 2S connector and look for continuity out to the pigtail that connects to the charger. It sounds like you may have an open trace on the PCB which will cause this error. Let me know how you make out, thanks.
Feb 24, 2012, 12:00 AM
Thanks for the explanation. I was plugging the RJ2 plug in to Ch 1.
Now that I am plugging RJ1 in Ch1 I can get 1 channel to charge but when when I try to do both channels I get a bad cell count on Ch1, I have used each board by itself in Ch1 OK but as soon as I try 2 channels I get the bad cell count on Ch1
Feb 24, 2012, 10:32 AM
Sindland MC SAA
Hi,
Are you connecting two seperate packs or is the output connector wired in series? If you are charging using the discharge leads, make sure the pack that is connected to channel one has the discharger leads connected to the black and yellow banana jacks for channel 1 (the first 2 banana jacks on the left) and for channel 2, the yellow and red for channel 2 (the two banana jacks on the right). Also, if you can take a continuity reading between the two yellow banana jacks posts, it should read a closed circuit. If this reads open, the internal fuse is blown and must be replaced. Last, make sure the charger is in the FMA wiring mode and not XH mode. Let me know, thanks.
Feb 25, 2012, 08:54 PM
I do get an open circuit reading when I check between the 2 yellow middle jacks. Where is the fuse that is blown. All I find is a 45 amp fuse which appears to be soldered to the circuit board.
Feb 26, 2012, 12:50 AM
President, FMA, Inc.
Tim Marks's Avatar
Hi:
If you wish to replace the internal fuse between the yellow banana jacks, you have to remove the top panel. There is a small 15A black fuse that is soldered between the jacks. If you contact Howard via email at howard@fmadirect.com, he'd be happy to send you a fuse. Or you can use a standard 15A blade auto fuse. Mini blade fits easier if you can locat that. If you don't have decent solder skills, you can contact Howard and arrange to return the unit and he'll fix you up.
This fuse gets blown instantly when you put a battery across the two yellow jacks. This is why there is a skull and crossbones on the top panel silkscreening.
Tim Marks
Feb 27, 2012, 10:09 AM
Sindland MC SAA
Hi,
This should help:
Cellpro 10S Internal fuse...
Mar 02, 2012, 12:16 AM
Found fuses and replaced the blown fuse. Charging 2 batteries at once now. Thanks for all the help
Mar 02, 2012, 10:09 AM
Sindland MC SAA
Hi,
I'm glad you have it working, one less repair for me!
Feb 19, 2017, 05:58 AM
10 x charger
Hello Howard
I have a 10x charger that is not charging properly. The charge starts ok.. ie 2.2a, but then drops back to .3a or so.. Any idea what the problem could be.. ps, I had to re load some pre sets, but cant remember why
Regards
Col
Feb 27, 2017, 10:39 AM
Sindland MC SAA
Originally Posted by Col Collyer
Hello Howard
Regards
Col
Good Day,
What is the cell count of the pack you are charging? What is the specifications of the power supply you are using? Check what you have the current limit set to.
Howard
Sold 2 x Cellpro 10s Charger, excellent condition, with TP/PQ balancing boards... jfetter Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jul 20, 2011 02:24 PM
Sold cellpro 10s with cables and adapters for tp/pq + pc link RevToTheRedline Aircraft - Electric - Batteries & Chargers (FS/W) 7 May 07, 2011 12:48 AM
Sold FMA Direct 4s charger with TP and PQ adapter. Stall'n_N_Haulin Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 08, 2011 07:45 AM
Sold FMA Cellpro 10s Charger with TP/PQ adapter Eury Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 12, 2010 12:20 PM
Sold FMA Cellpro 4S (4amp) Charger + TP/PQ Adapter Blendo Aircraft - Electric - Batteries & Chargers (FS/W) 3 Oct 21, 2008 12:06 PM
