Optimized RCExplorer Tricopter Template - RC Groups
Feb 18, 2012, 03:46 PM
Download
..:: Optimized RCExplorer Tricopter Template ::..
An optimized tricopter template based on the design by RCExplorer.se
Hi everyone!
After using the RCExplorer template for their tricopters, several people came to the conclusion that the original RCExplorer template could be a bit better. So I started to design a new template based on the RCExplorer design, and after several hours this design was born.These were the improvements made:
- 120║ between booms
- CG point at axis intersection
- KKboard centered over CG point
- all screws more than 8 mm from edge of plate
- design still foldable- all screws 3mm
- minimal changes to profile, still looks sexy
Five days later, a friend said he tried out the modified design and it worked out nicely, it could even be used as a T-copter instead of the normal Y-configuration. That inspired me to make this modified design more user-friendly, so that more people could enjoy the benefits of the new design.
- Frame can now be used as a T-copter
- Power cables can now be run inside the frame
- Boom pivot further out from CG
NOTICE: The original design belongs to RCExplorer.se . As the new template is completely based on his design, i cannot claim ownership of it. The new design still belongs to RCExplorer.se . I will only shamelessly claim credit for the improvements made to the design, while staring in amazement at the guy who brought multicopters to the masses.
Original Design by RCExplorer
Modifications, CAD, and graphics by colorex
Beta testing by ananas1301
File Hosting by UndCon
Download!
Latest verion: 1.2
The files are now hosted at the following website:
http://undcon.com/colorex
Click on any image to download.
Version Log
Version 1.0
Version 1.1
- Fixed switched titles on page 1
Version 1.2
- Added modifications so you can use 9 mm, 10 mm, or 12 mm booms.
- Added the optimized RCExplorer.se "coffin" design. Only available for 10 mm booms.
- Added the Battery and Camera plate.
- DWG and DXF files available for download. These are for use in CNC/Laser Machines.
- Files now hosted on http://www.undcon.com/colorex
Please rate and comment this thread!
Feb 19, 2012, 06:42 AM
David Jenkins's Avatar
When I click on the image I get asked to log in...
Feb 19, 2012, 07:11 AM
it looks like they copied it from a different forum
Feb 19, 2012, 08:59 AM
Old new guy
TheX's Avatar
If you decide to sign up over there the answer to the random question is Joshua. The show they're referring to is their Youtube channel.
Feb 19, 2012, 09:47 AM
Ooops!
And yes, I posted it on flitetest.com first, then tried using the same links for this forum... I'll fix that now.!
Feb 19, 2012, 09:52 AM
Fixed, sorry for the inconvenience. Please give feedback!
Feb 19, 2012, 09:54 AM
Old new guy
TheX's Avatar
Y and T copter images are mislabeled (reversed).
Feb 19, 2012, 10:23 AM
Fixing!
Feb 19, 2012, 12:06 PM
Fixed!
Feb 23, 2012, 11:42 AM
Here are some pictures:
Feb 23, 2012, 12:52 PM
Shouldn┤t the CG be another one for T-Copter ?
Cheers,
Frank
Feb 24, 2012, 05:29 AM
Cheers,
Frank
Yes, the CG will be further back along the rear arm. This tri setup as a T is not your conventional evenly spaced motor to motor design. It will fly but id imagine it would have a very sensitive pitch and slower roll response.
Feb 26, 2012, 04:56 PM
If the CG is not adjusted, the tricopter will be sensitive to tilting forwards, but slow to tilt backwards. The CG in the case of the T should theoretically be 16.6 cm from the conventional Y-type CG. This is accomplished by moving the battery towards the back, strapping it to the arm.
Feb 27, 2012, 02:21 AM
The following site is very useful for getting the balance right on a T-copter...
http://lloydhassell.brinkster.net/rc...alculator.html
Just enter the details of your airframe and it will suggest a suitable CofG point.
Feb 28, 2012, 04:08 AM
Crazy1's Avatar
Based on the David's RCExplorer tricopter, I built my Tcopter with the motors and CofG in the same place as his v.2.5. Mathematically calculated the front motors will be 866mm (34.1") apart, axel to axel, and the boom to the rear motor axel will be 750mm (29,5"). Allow about 1/2" extra to be able to mount the motors.
Discussion Mini tricopter RCExplorer style, 30cm, 220g rolin Multirotor Drone Talk 4 Jun 10, 2012 08:51 PM
Help! Help with tricopter from rcexplorer.se JoseOlcese Multirotor Drone Talk 4 Feb 19, 2012 06:46 AM
Discussion Which copter body on an rcexplorer.se tricopter? David Jenkins Multirotor Drone Talk 2 Nov 26, 2011 02:53 PM
Discussion "Flying High" video by RCExplorer dadde Multirotor Drone Talk 15 Aug 29, 2011 08:05 AM
Discussion New Tricopter video from RCExplorer - "Leaf blower" dadde FPV Talk 3 Nov 09, 2010 03:44 PM
