This thread is privately moderated by billpa, who may elect to delete unwanted replies.
May 08, 2017, 07:11 PM
Wintr's Avatar
Originally Posted by choochoo22
No.
In 3D HH trimming will have no effect until quite a bit of trim is applied and then your HH will unlock. In 3D no HH trimming would be OK until you change to another mode.
Unless direct rate is on; then, if the trim is large enough, the G will interpret the trim as a rate command, and continue to rotate the aircraft on that axis.
In 2D trim will have the effect of applying a small offset to the established level setting. This might seem like a good idea but when you switch to a different mode or execute 1 or 2 gestures it can cause unwanted changes.
The right way to trim with a G is off, then execute 1 or 2 gestures after landing.
Best way to trim, hands down.
May 10, 2017, 01:06 PM
Here's another case for the G from RMRC, for $4.99.
It encloses the G.
I just ordered some. They don't show them in stock, but if you contact them they will 3D print them for you.
https://www.readymaderc.com/store/in...oducts_id=3981
May 10, 2017, 05:05 PM
Where did that tree come from
kid at 55's Avatar
Guardian 2D/3D Stabilizer problem
Been flying with this Guardian 2D/3D Stabilizer for six months now with no problem. But today when I would put it in 3D mode it would change the ailerons by 2 or 3 degrees. 2D mode is fine. I had a servo to go out with me and I replace both ailerons servos. This was the first flight with the new servos in her. Do I have to go back and redo the trimming step as if it was the first time with the Guardian again ?
May 10, 2017, 06:17 PM
Yes
May 10, 2017, 07:56 PM
kid at 55's Avatar
Originally Posted by Al M
Yes
Okay. It's time to refresh my memory with the manual.
May 11, 2017, 08:03 AM
kid at 55's Avatar
I'm back in business. Thanks AI M.
It's tough getting old.
May 11, 2017, 12:19 PM
Beats the alternative...
May 11, 2017, 06:00 PM
Galand's Avatar
Fantastic reply!
May 14, 2017, 05:24 AM
Learning to crash
Tom T's Avatar
Just want to say Thanks Eagle Tree! Maidened the Guardian equipped P51 last night and she flew like she was on rails. Just kept it in 2D for a shakedown flight.
Maiden flight FMS1700 P-51 (6 min 10 sec)
May 14, 2017, 12:28 PM
"Some do, some don't"
old_coastie's Avatar
https://youtu.be/a9j_Ip389JY
Tom,
Congratulations on the maiden, must say that model has a great "presence" in the air....
You know if more pilots followed your example on a maiden flight there would be a lot less crashes and you nailed that maiden landing great job.
Mark R.
old__coastie
May 14, 2017, 06:34 PM
Learning to crash
Tom T's Avatar
Thanks Mark. Just flew it cautiously to get the feel of it. Is my first large'ish warbird (have the 1.2 blondie and 1.2 Spitfire) and wasnt exactly sure how sluggish it was going to feel. Might have come in a little hot with half flaps, but didnt want to slow down too much.
Jun 25, 2017, 10:10 PM
An aspirational fast jet pilot
Great_Goose's Avatar
Does anyone know if you can run dual elevators (separate servos on separate channels) on the Guardian?
Jun 26, 2017, 06:40 AM
Michael
Assuming you're not talking about elevons, then not directly connected to the Guardian, but the single elevator channel can be connected to, for example, a SmartFly Equalizer II (http://www.smart-fly.com/equalizer-ii).
and that gives you individual center / reverse / end point adjustments and the Guardian controls both elevators thinking it is only one.
I've used one for several flying seasons on my 1/4-scale RV-4 and it has worked great.
Michael
Jun 26, 2017, 09:33 AM
I had the same question, but GG beat me to it.
The Equalizer looks like a good solution, but it's out of stock.
Unless someone has a better solution I think I'll just put the servos on a Y.
Jun 26, 2017, 11:24 AM
Michael
A "Y" will work unless you have to reverse one of the servos (my case).
If you are flying with a Spektrum Rx, it is my understanding that a servo reverser is prohibited; a "Y" will not work in that case.
Some Hitec servos can be reversed using their programmer.
If a "Y" will work, then simpler is better, IMHO.
Michael
Discussion Can I control Guardian stabilizer with DX6i? njwxyz Eagle Tree Systems 9 Jun 02, 2014 12:17 PM
Discussion GPS 2D Plots incomplete, 3D OK jackerbes Eagle Tree Systems 1 Oct 23, 2011 09:42 PM
Discussion Premier 1st generation, Gen 2 Vector unit, 2D or 3D motor unit lanternfly RC Paragliders and Kites 0 Oct 05, 2011 09:42 PM
Data 2d or 3d wing ribs? Marty7n Beginner Training Area (Aircraft-Electric) 56 Sep 22, 2011 04:06 PM
Discussion 3View to 3D to 2d techasist CAD/CAM 0 Mar 27, 2011 12:19 AM
