Oct 01, 2015, 03:14 AM
Crashing in style.
Bazed's Avatar
Sorry, hope this is not a daft question... but what are the benefits of this 1s osd over using a micro minim osd? as far as i can see, the minim software gives much more info and features...?
Oct 01, 2015, 06:10 AM
Don't leave it Stock
mrfliboy's Avatar
Only needs single cell lipo to work. 3 Volts is all.
Perfect for us micro fliers.
Oct 01, 2015, 06:12 AM
Crashing in style.
Bazed's Avatar
Ah ok, overlooked that. Thanks
Oct 02, 2015, 03:34 AM
ultra cheap pilot
ican3d's Avatar
Its here!! OMG! Awesome!! Thanks FPVinstanbul (FPVHOBBY.COM). I'm gonna install in my micro toy quad and ninja around the park soon. Gonna put some test and serious review on this thing.
Photos:
Oct 02, 2015, 06:08 AM
Works well
I made first tests and very satisfied, OSD does not introduce any noise and shows exact voltage (more accurate than my voltmeter )
I use both inputs indicating battary voltage as well as the voltage at the VTx. The scheme is attached.
The weight of FPV components (DC-DC converter, LC filter, OSD, VTX, camera) is 8.6 g. It is still a test version, where I use connectors. Withouit these connectors I wil land at 6-7 gr.
Wishes (subjective) for V2 OSD:
1. possibility to adjust the position of voltage indicators on the screen (e.g. to put them at the bottom)
2. Only one voltage indicator (or an ability to disable one of the indicators on the screen).
David
Oct 02, 2015, 06:00 PM
Am I right in saying this version doesn't have a built in vreg? But an updated version will have
Oct 04, 2015, 07:24 AM
got mine working today its fantastic
Oct 04, 2015, 11:53 AM
Want
Oct 07, 2015, 07:19 PM
ultra cheap pilot
ican3d's Avatar
I got mine worked great too, support 2x 1s lipo, did test full throttle no lines. Nice!!!!! Too bad he gave me 1x piece of micro OSD since i have dozen of micro FPV quad. Will post video of FPV live OSD flight next Saturday test flight.
Photos:
Oct 07, 2015, 07:43 PM
when you say no lines on the video are u using a vreg with your setup already or are u suggesting that the OSD is regulated?
the instructions suggest that input and output are the same ie 0-6 volts suggesting its not regulated
EDIT! just seen u are using a separate battery for your fpv power. so no need for a vreg. interesting we can do that now we have two voltage
readings. just to be clean i like to use the same battery for my fpv gear and quad power
Oct 09, 2015, 12:30 PM
mrfliboy's Avatar
Quick video flying around my shop (MQX) and trying out this great OSD. THanks again
05 0101 00 12 39 (3 min 7 sec)
Oct 09, 2015, 07:26 PM
https://www.youtube.com/watch?v=vHOE...ature=youtu.be
the osd appears much higher up on mine than it does on yours. i wonder if u have a different version. good video
Oct 10, 2015, 04:34 AM
There is only one version already. Differencies can be because we are using PAL and NTSC cameras.
Oct 10, 2015, 05:23 AM
I thought that might be the case. thanks
Oct 10, 2015, 09:49 AM
my initial tests are showing that the OSD is very power hungry itself. I am not getting very long flights at all. has anyone else found the same? usually with my FPV gear I am gettin 10 minute flights but only 2-3 minute flights with this setup unless something is wrong
Sold Eflite celectra 1s 3.7 variable rate charger and two Eflite 1s 200mah 25c lipo's $21 nitrodude71 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Jan 06, 2012 08:59 PM
For Sale FS/FT CRC Gen XL - Xerun 120a 1s - Duo 3 - 1s Lipo - Extras SNIPR Cars - Cars and Parts (FS/W) 1 Apr 19, 2011 02:32 PM
Sold Heli-Max 1S LiPo Charger with two 1S 600mAh 15C LiPo's $15 nitrodude71 Aircraft - Electric - Batteries & Chargers (FS/W) 6 Jan 13, 2011 10:04 PM
Sold eflite 3.7v 1s 120mah lipo's tenergy 3.7v 1s 130mah lipo's nitrodude71 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 17, 2010 01:05 PM
Sold 1s parkzone 3.7v 1s charger with five 1s lipo packs hacker002 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Dec 11, 2009 04:56 PM
