Feb 07, 2012, 05:43 PM
Question
pica 1/8 Corsair kit tail or nose heavy?
Hi,
I will be starting soon working on a Pica 1/8 Corsair .60 kit. I am in the process of selecting an engine, and I'd like to put a RCV 90SP. However,
I am wondering if this kit comes tail or nose heavy. RCV engines are 20 to 40% heavier than similar displacement standard 4-stroke
engines. If the plane is tail heavy, I do not mind the extra weight (rather have weight in a cool engine than dead lead), but I do not want to have to add further weight in the tail if the plane is nose heavy to begin with...
Alberto
Feb 08, 2012, 02:52 PM
This kit was designed with the nose longer than what is scale and the plane balances quite well. Your RCV should be fine. The tail builds light. There is a design flaw in the in that the rudder horn interferes with the fuselage side which requires you to cut out a relief hole. The tail section tapers to a point so keep that in mind if you have to add weight; there may be no place to put it.
Feb 08, 2012, 09:08 PM
Thank you! I will watch out for the rudder horn.
Feb 11, 2012, 09:03 PM
I started looking at the kit and noticed that no mention is made of 4 stroke engines.
Usually, other kits indicate the appropriate range for both 2 and 4 stroke engines.
I wonder if this was really an oversight,, or the kit was specifically designed for lighter
2 stroke engines... I guess I can wait to sheet the very last section of the tail and see.
I'd really like to use a 4 stroke ....
Question topflight 1/7th size kit balance point per plans is 37/8 with ST 75 engine is nose he logair8452 Scale Fuel Planes 0 May 19, 2011 02:08 PM
Discussion Are Pica 1/12 "ART" warbirds relatively heavy compared to kit counterparts? DaveInLA Electric Warbirds 2 Mar 23, 2007 07:07 PM
For Sale Pica F4U Corsair 1/8th Kit andernamen Aircraft - Fuel - Airplanes (FS/W) 3 Jun 21, 2006 02:00 PM
WTB: PICA RC-30 F4U CORSAIR 1/12 Scale KIT Mickey Aircraft - Electric - Airplanes (FS/W) 2 Mar 08, 2005 01:45 PM
