Saito .91 Rocker Shaft Thread Repair
Thought I'd share my recent experience with repairing the best running engine I've ever had, a .91 Saito Golden Knight that I bought about 7 years ago.
I noticed a louder than normal "clicking" in the top end & discovered the exhaust rocker arm shaft had loosened and damaged the threads to where it would not tighten up which made it impossible to adjust the tappet clearance . I was bummed ![]() After talking to a number of folks, creatively brainstorming on different repair options & looking through some forums I had come to the conclusion I was going to have to break down & spend the money but then I realized the threads were 3mm X 0.50, pretty standard stuff so I located a heli-coil kit with no difficulty at all and for about $46 I seem to have satisfactorily fixed it. ![]() ![]() ![]() The first step of drilling out the damaged threads and making sure it was square was a little nerve-racking but the next step seemed to be more crital and a little easier as I carefully lined up the special thread tap and cut the new threads making sure as I went that everything looked good and straight. I then ran the insert from in between the rocker arm supports outwards so I could more easily remove the excess material, which also allowed me to confirm proper fit and depth on the rocker pin and I actually ground the excess insert material with the pin in place and tight which probably kept the Dremel bit from spinning it right out of place. In addition the heli-coil kit came with another 19 inserts and the same threads are used in mufflers and a handfull uf other applications so it might save me more in the future. BTW, in my research I discovered that on the larger, 120 & up Saito's the rocker housing by itself is available. I hope this will help someone in the future and I might consider selling the heli-coil kit for half price if anyone is interested. ![]() |
Forgot to add photos to the previous post.
That is a really nice repair job you did there. It is looking really good.
Latest blog entry: I got back into FPV for a while again.
Granger wanted almost twice that price so I thought I was doing OK with what I did spend, the one I got came from Zoro Tools in IL whom I found on line and I received it within days of ordering so their service was great. I'll keep the others in mind for any future needs, thanks!
Nice repair.
Had the same thing happen. I found next size up SAE bolt/screw. Tapped the hole with the threads messed up to the correct size. Cut the head off the bolt/screw and slotted it with my dremel. Screwed it in with a little blue loctite. Didn't even have to re-size the rocker arm. $6 including the tap I had to buy. |
Thread Tools | |
Similar Threads | |||||
Sold | Saito FA40 Open Rocker Four-Stroke | redball8 | Aircraft - Fuel - Engines and Accessories (FS/W) | 0 | Oct 29, 2011 09:11 AM |
Sold | Collectors NIB Saito FA-40 Open Rocker 4 Stroke $300.00 FREE SHIPPING!! | stevster | Aircraft - Fuel - Engines and Accessories (FS/W) | 7 | Jul 08, 2011 07:10 PM |
Discussion | I just picked up a Buccaneer with Saito FA30 Open Rocker Engine | TexasClouds | Vintage & Old-Timer Designs | 20 | Jul 05, 2011 06:07 PM |
Sold | Vintage Saito FA40 Open Rocker | dls | Aircraft - Fuel - Engines and Accessories (FS/W) | 1 | Jun 04, 2011 09:46 PM |
Help! | Broken Bolt on rocker arm cover for Saito 100, 4 stroke | rather_be_flying | Fuel Plane Talk | 8 | May 04, 2011 03:29 PM |
