Feb 04, 2012, 08:50 AM
Kit Manufacturer
coreman's Avatar
Flat Foamie Series from RA Cores
We have started selling our EPP and Depron flat foamie planes and I am getting several questions and great hints back from customers. I would like to use this as a common area for people to discuss the kits. The first kit in the series is our version of the popular Leadfeather Yak55
our page of the kits is at http://www.racores.com/FlatFoamies.html
Latest blog entry: Release of our 40" EPP Yak55 XL
Feb 04, 2012, 09:10 AM
pondside
pondside's Avatar
Great idea Jim, my experience, as well as others who are beginners/intermediate spend more time fixing rather than learning. Alan and Scott have some great ideas to make the planes more durable, more time flying, less time fixing.
Bob
Feb 04, 2012, 09:19 AM
Kit Manufacturer
coreman's Avatar
Bob
and a customer's success and enjoyment is the best advertising.
Feb 04, 2012, 01:10 PM
ArduVidRx Creator
etheli's Avatar
We've been having a lot of fun flying streamer combat with the 28" EPP Yaks, both at the field and in the Auburn dome. Jim's kits make it really easy to put one together. The more the merrier...
--ET
Feb 04, 2012, 02:55 PM
Kit Manufacturer
coreman's Avatar
--ET
yep, and Alan's technique with the spiderwire that he used on the plane Chris was flying seems to work very well. Even with the head on impact he had with me, he cracked the wing but it didn't separate and he kept flying. I am hoping he can explain how he did it here.
Feb 04, 2012, 10:37 PM
Teambarger's Avatar
I am getting pretty good at bouncing the Yak off the ground so maybe I can give some crashing tips. 1st tip : Watch Jim fly and don't do what he does !
Feb 05, 2012, 01:26 AM
Being new to foamies, I see the yak has some rods for bracing, do these come with the kits? If not what are they and can I get them at a hobby shop?
Feb 05, 2012, 05:17 AM
Kit Manufacturer
coreman's Avatar
Well, I did see you fly into the wall while you were busy watching MY plane...oh wait, that was me. There is that walk of shame across the field to pick it up and toss it back in the air.
Feb 05, 2012, 05:27 AM
Kit Manufacturer
coreman's Avatar
for our kit we decided to use the foam diagonal bracing for the tail. It stiffens the tail just about as much and is a lot easier to install. If you are meaning the wing and tail spars and the pushrods, those are included in the kit, as are the plywood horns and motor mount. You really just need glue and tools to build the kit (and we sell UHU also for the EPP construction)
Check out our online instructions to see the build process and everything in there is included in the kit. And all the electronics (motor/ESC/Servos) are available in the Completer kit we also sell so you can build a receiver ready version out of the parts we sell for cheap money.
Feb 11, 2012, 10:23 AM
If I fly the Yak 55 EPP version outside with a 1300 motor, what battery should I get with 3s lipo and how long should it last?
Feb 11, 2012, 10:30 AM
Kit Manufacturer
coreman's Avatar
You should get 10-15 minutes with a 1000mah but it depends on what you do for maneuvers. Shorter if you do a lot of hovering or WOT stuff. I'm getting 6+ minutes indoors with 460mah nanotechs at the moment. Depends on how you prop it. I'm using a HD8040 GWS personally and last year I flew them outside that way last summer. My batteries had been drooping a little after 2 years of near continuous use and the new ones are giving me plenty of power and time
Feb 14, 2012, 04:15 PM
I built RACores EPP YAK 55. The only change I made to the instructions is I used DU-BRO Mini E/Z Connectors to set up the control surfaces. It made the set up and adjustment very easy.I had the maiden flight today at four kicks in Norfolk Ma. I used the following set up.
Ailerons
Low Rate: 1-inch (25mm) with 20% Expo (Up/Down)
High Rate: 2-inch (50mm) with 40% Expo (Up/Down)
Elevator
Low Rate: 2-inch (50mm) with 20% Expo (Up/Down)
High Rate: 2 3/4-inch (70mm) with 45% Expo (Up/Down)
Rudder
3 1/2-inch (89mm) (Left/Right
I used all low rates.
I did find the EPP appears to change dimensions a lot out doors at 25F. The controls changed dramatically.
Feb 14, 2012, 10:11 PM
Kit Manufacturer
coreman's Avatar
Ailerons
Elevator
Rudder
You are right on the EZ Connectors, they are just too expensive to put a retail package into the kit. I have used them myself in the past and like them. interesting observation on the EPP size change
Mar 03, 2012, 06:23 AM
crash and burn
brandonbuck1's Avatar
Thanks for all your help setting up my plane yesterday Jim. Its very much appreiciated. For cheap money you get a great flying plane. I'll be sure to order more in the future. Thanks again Jim.
Mar 03, 2012, 07:02 AM
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
DUBRO has OEM bulk pricing.
Azarr
New Product RA Cores Product announcements coreman Product Announcements 8 Mar 14, 2014 01:20 PM
Discussion First Flat foamie 3d plane...need help. skeasor 3D Foamies 12 Aug 11, 2011 01:42 PM
Discussion building a flat foamie roneng Foamies (Kits) 4 Jun 29, 2011 10:19 AM
Help! 64mm shroud vibrating in a flat foamie THX-181 Foamy EDFs 5 May 06, 2011 05:46 AM
Wanted ra cores gremlin boko Aircraft - Fuel - Airplanes (FS/W) 1 Feb 12, 2007 11:40 PM
