This thread is privately moderated by ExperimentalAir, who may elect to delete unwanted replies.
Nov 01, 2018, 08:11 AM
Originally Posted by TooJung2Die
Curl it in the other direction over the edge of a table. The same technique used to make airfoils with the paper removed inside and left outside.
Tried that. It ended up breaking . The foams kind of lime hk foam but slightly less brittle. The curve just goes back. It's quite thick paper.
Nov 01, 2018, 01:33 PM
Epilepsy Awareness
Flying High Mike's Avatar
I have bent and formed foam with a real hot rag placed on top. You have to keep this rag very hot at all times until the foam is to your liking. Hope this helps.
Nov 01, 2018, 07:47 PM
snowball
I have recently have run in with a teacher willing to try r/c in the school, if anyone could give me basic specs for the pizza box or snowball along with starting throws I would appreciate it
Nov 02, 2018, 10:12 PM
check out flitetest.com
Nov 08, 2018, 12:22 AM
propsnapper's Avatar
You can find the full Nutball/Snowball thread here.
https://www.rcgroups.com/forums/showthread.php?t=836389
You can also find the PbF thread here.
https://www.rcgroups.com/forums/show...A-videos-plans
Both links are chock full of info about the planes you mentioned. Enjoy!
Nov 19, 2018, 04:28 PM
"Crunchies Rule"
oldscooler's Avatar
This is a new wing I am designing and have already produced a test panel. The actual wing which is about to be assembled will be a 2 piece 2.7m symmetrical for glider aerobatics.
E
53" Board wing 1 (4 min 47 sec)
Nov 19, 2018, 07:44 PM
skumgummi dave
oldscooler:
Is your spar tapered?
Dave-
Nov 20, 2018, 05:22 AM
Quad and foam adept
Hermani's Avatar
In the pictures the wing looks almost symmetrical in shape. What airfoil do you aim to achieve?
Latest blog entry: WoodQuad
Nov 20, 2018, 10:41 AM
"Crunchies Rule"
oldscooler's Avatar
Originally Posted by foamdave
oldscooler: Is your spar tapered?Dave-
No it is not yet.
Nov 20, 2018, 10:45 AM
"Crunchies Rule"
oldscooler's Avatar
No particular airfoil. First flights will tell us a lot how this thin foil will do. When I reveal the way we are flying you will see foil designation isnít really a concern as long as itís just Sym.
Dec 04, 2018, 07:52 AM
Let's fly!
My Latest - Noob Tube 30
30 inch wingspan
Turnigy XK2845-3650kv Inrunner
60 amp ESC
7x5 prop
3S 1500-2200 batteries
I had the parts from previous projects, including the dollar tree foam. Hoping for light winds today for maiden.
Adam
Dec 07, 2018, 08:08 PM
Originally Posted by Flying Low
30 inch wingspan
60 amp ESC
7x5 prop
Adam
I've been meaning to make a 3d version of the noob tube. Shoiuldnt be too difficult. Maske the wkng with much larger cord big silerons. Mod the tsail with bigger elevaote and rudder.
And moiunt the WK g and tail in middle of fuse iknsead of top.
Dec 08, 2018, 02:57 AM
"Crunchies Rule"
oldscooler's Avatar
Why not consider going bigger like 2.5 meter? The wing assembly process has been recently proven, and the prototype glider for low flying aerobatics is nearing completion.
EJ
53" Board wing 3 (6 min 26 sec)
53" Board wing 4 (5 min 44 sec)
53" Board wing 5 (12 min 58 sec)
Dec 08, 2018, 03:01 AM
"Crunchies Rule"
oldscooler's Avatar
2.5m foam board wing half
Here it is...
Dec 08, 2018, 05:09 AM
Reap the wild wind
headlessagain's Avatar
30 inch wingspan
60 amp ESC
7x5 prop
Adam
I'm not sure how long that high a kv motor on a 7x5 prop on 3s is going to last
A 6x5 on a 2200kv is about the max so I'd expect something to smoke
Andy
Discussion EDF/Motor for University Design Project uwpropulsionguy Electric Ducted Fan Jet Talk 2 Oct 14, 2018 04:51 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Foamies (Scratchbuilt) 76 Apr 20, 2018 09:24 AM
Build Log SEW-SLO 30" Foamboard Wing Atx_Heli Flying Wings 0 May 19, 2011 09:47 PM
Question So I have a sheet of $Tree foamboard... what to build? Bomb Dropper Foamies (Scratchbuilt) 15 Mar 23, 2011 02:49 PM
