Feb 01, 2012, 10:23 AM
"The Judge"
sebbe's Avatar
Hitec hs65 HB and voltage ?
hello, is it ok to run these servos @ 6 volts all day long?
I have a Hobbywing Platinum where the option is to run the BEC at 5.25V/6V, I want the max strenght of the servos..thats why I want to run on 6V.
Sebbe
Feb 01, 2012, 01:12 PM
Originally Posted by sebbe
hello, is it ok to run these servos @ 6 volts all day long? I have a Hobbywing Platinum where the option is to run the BEC at 5.25V/6V, I want the max strenght of the servos..thats why I want to run on 6V.
Sebbe
Yes, Rated 4.8v < 6.0v.
However as with any servo, the higher the voltage, the higher the speed of the servo and thus current draw
which results in a somewhat shorter life span of the unit in use.- always a balancing act.
HS-65HB Mighty Karbonite Feather Servo
"Considered one of the most powerful servos in the micro class, the HS-65 is offered with a choice
of “shock resistant” Metal or “zero wear” Karbonite gears.
The 65 series features a top-ball bearing for long life and positive centering, 31 ounces/inches of power at 6 volts
and is an excellent choice for higher performance micro helicopters, electric park flyers, and 1/18 scale cars. "
Specifications:
Motor Type: 3 Pole
Bearing Type: Top Ball Bearing
Speed (4.8V/6.0V): 0.14 / 0.11 sec @ 60 deg.
Torque oz./in. (4.8V/6.0V): 25 / 31
Torque kg./cm. (4.8V/6.0V): 1.8 / 2.2
Size in Inches: 0.92 x 0.45 x 0.94
Size in Millimeters: 23.34 x 11.43 x 23.88
Weight ounces: 0.39
Weight grams: 11.06
See also sub Section "Radio Systems, Accessories, Alterations and FAQ." at:
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Feb 01, 2012, 02:20 PM
"The Judge"
sebbe's Avatar
ok, thanks, seems no problem at 6 volts..
Wanted Looking for 2x Used HS65-HB's poiyt Aircraft - General - Radio Equipment (FS/W) 0 Jan 18, 2012 12:38 PM
Found 4 Lightly used Hitec HS65 HB servo's - $60 shipped Premium2000 Aircraft - General - Radio Equipment (FS/W) 1 Jan 05, 2012 10:48 AM
Sold (5) Hitec HS65-HB Khosravi Aircraft - General - Radio Equipment (FS/W) 2 Dec 08, 2011 04:39 PM
Wanted WTB: HS65-HB Servos vgrewal Aircraft - General - Radio Equipment (FS/W) 2 Apr 27, 2011 09:12 PM
Sold 3 hs65 hb andresmirt Aircraft - General - Radio Equipment (FS/W) 2 Apr 13, 2011 12:31 PM
