This thread is privately moderated by Jim.Thompson, who may elect to delete unwanted replies.
Jan 24, 2012, 02:42 AM
Entropy is happening!
Jim.Thompson's Avatar
Moulded Wompoo progress.
I have cut the foam cores for the wing plugs. The cores are in 5 panels with one panel parrallel for the centre section. The plan is to glue ply or fibreglass laminate ribs to each end of this centre section and to the mating ends of the wings prior to joining. A piece of wing joiner tube will be in place also, embedded in the foam cores so that joiner rods can be inserted in the finished plugs to set up the mould accurately. I will glue them together with a thin cardboard spacer so that they can be easily and accurately cut apart with a thin kerf hacksaw after the complete wing is fibreglassed and vac bagged.
The joiner rods then become the alignment jig for the final wing and fuselage tubes.
I am about to layup a fuselage out of the old mould to build on to make the final plug. The centre section (above) has to be incorporated with their tubes etc. The "V" tail joiners have to be included in the plug. Then a "final" mould will be made from that.
The challenge as I see it, is the "V" tail joiners........
More soon.
Jim.
Build Log Wompoo Build Log Jim.Thompson Composites Fabrication 933 Nov 12, 2015 10:21 PM
New Product Ritewing ZII moulded Zephyr brosius85 Flying Wings 65 Dec 17, 2011 03:11 AM
Alert SOLD - Magnificent ALL MOULDED ASH 25 Ren DiLeo Scale Sailplanes 6 Oct 02, 2011 07:37 PM
Wanted Motor Mount for Funjet/Funjet Ultra (Moulded Plastic for Fusulage) rcwarrior Aircraft - Electric - Jets (FS/W) 0 Sep 04, 2011 12:11 PM
