Blade msrx left turns difficult ?? Any way to mix out on transmitter
Got the msrx finding left turns really difficult don't know much about mixing but was wondering if anyone has had same problem?? and if so what programming can a put in to make left turns easyer Thanks
This was discussed on the New MSRX thread and someone said they put some fwd elevator andaileron roll mix into the rudder control others said they just did the combination manually while turning. I don't remember exactly the number but you could find it by reading the thread starting at a point after people started receiving the heli.LOL
Everything you need to know is right here:
https://www.rcgroups.com/forums/show....php?t=1577468 - you must adjust the servo linkages, not the stick trims. - you must disable the AS3X 'heading hold' in order to observe and adjust the trim. - 3 clicks of rudder trim will disable the AS3X 'heading hold' |
Adjusting trim is "only" for helping turns, not hover (imo). |
unfortunately after a month of trying everything i came to a conclusion that the msrx is buggy and no amount of mix can copensate for the fact that it resets the swash plate on rudder input.
What i mean is that in hover you have 0% aileron. on slow turns you have 10% aileron. On faster turns you have 20% aileron. etc. In all these situation, the swash plate levels to 0% on rudder input So the amount of mix you need in every single situation is not constable. So no amount of mix will be able to provide a stable all around flight. I bought the msrx because it is supposed to be a good "teacher" for moving on to bigger hellis. But instead of learning to flight, you just concentrate on learning to overcome the as3x commands that you don;t want. I also bought the dx7s for the mix (I didnt need any d/r or expos on the stock Tx) and it also now is useless. They should come with a v2 version asap that leaves the swash plate alone when you want to rudder |
UltiMo_ you joined today and you've made 4 posts in three different mSRx threads with the same complaint. It doesn't sound like you're looking for a good "teacher" to me as you've completely ignored all the excellent knowledge available in each of those threads. |
No mix seems good for meQuote:
I do not use the MMM mod, only some D/R and expo. |
Thread Tools | |
Similar Threads | |||||
Discussion | Right Turns vs Left Turns | mrsam22 | Electric Plane Talk | 61 | Oct 19, 2018 06:52 AM |
Discussion | Blade MCPX -- sometimes yaws left out of control. | lawlist | Beginner Training Area (Heli-Electric) | 0 | Oct 24, 2011 05:05 PM |
Discussion | New ESC - motor turns wrong way on start-up | jeff2 | Electric Heli Talk | 6 | Aug 29, 2011 10:40 AM |
Discussion | Mini slinger turns to the left unless lots of up aileron on the right | GooberSB | Flying Wings | 3 | May 31, 2011 11:18 PM |
Discussion | Steering SETUP? Right on TX Turns forks Left Or Right Turns Right? Correct Setup? | Mr. Miyagi | Motorcycles | 10 | May 22, 2009 08:52 AM |
