Jan 22, 2012, 04:30 PM
Ripmax pro dual output.
Hey there.
I have one of these, and i would like to know if what i am about to do is ok.
I have two parkzone charger/balancers, and im planning on stripping the car charger and putting gold plated banana clips on them. Is it safe to use both chargers at the same time on this unit? (Im a little concerned because the unit says 13.8v, when max voltage for my 2200 25c is 12.6v)
Thanks a lot
Jan 22, 2012, 04:53 PM
Southern Pride
everydayflyer's Avatar
The setting on the charger determines the charge to voltage and the charge rate not the power source.
I often use a 24V 30A power supply with various Lipoly chargers to charge 1S to 4S LiPolys from 120 mAh to 3300 mAh.
Jan 22, 2012, 04:57 PM
Thank you, and stripping the car connector from the parkzone charger and replacing it with banana clips will be ok?
Sold Pro-Peak Dual Output 13.8v 20A Power Supply jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 17, 2011 01:28 AM
Sold Pro-Peak Dual Output 13.8v Power Supply jgalexander Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 13, 2011 02:46 PM
Sold Pro-Peak Dual Output Power Supply RickAir Aircraft - Electric - Batteries & Chargers (FS/W) 0 Aug 19, 2011 03:33 PM
Discussion Ripmax dual output PSU, erorr code 2 with Cellpros? Working fine yesterday? LaurenceGough Batteries and Chargers 2 Feb 14, 2008 02:53 AM
New Product Hobbico Pro Series Dual Output Dc Peak Charger Jim T. Graham Product Announcements 0 Jan 29, 2007 01:56 PM
