Want to know how to setup your IMU? Look Here - RC Groups
Jan 20, 2012, 07:21 PM
Emress
Mini-HowTo
There has been some talk in the drotek 10DOF IMU thread about creting a thread that has info on how to setup all the different IMUs to MWC. The goal is to reduce all the "Why wontthis IMU work?" threads; these have become more common since MWC 1.9 and the debug2 (I2C) errors(since it removed the workaround for incorrectly hooked up IMUs). Hopefully this thread will expand to contain instructions for most IMUs!
Pololu MinIMU-9DOF: http://www.pololu.com/catalog/product/1265
1. Connect GND from the IMU to the arduino GND.
2. VIN to a 2.6 to 5.5v source(Arduino 5v, or use a external power supply and a common GND with arduino)
3. SCL to Arduino SCL(A5, no pullup needed)
4. SDA to arduino SDA(A4, no pullup needed)
5. 3V and 1.8V out are available to use for other powering applications if you want, not required. SA0_G and SA0_A are also not needed. 400khz fast mode supported. define L3G4200D, LSM303DLx_ACC, HMC5883
Wii nunchuck and motion plus:
If you connect it as in the pic you shouldn't need to enable internal pullups on the Arduino. also check if your Wii acc/gyro board has a voltage regulator. if it does then you can give it 5v, if not then you must give it 3.3v.
if you have a strange Wii clone board, use the above picture and the continuity feature of your digital multimeter to find where the 5v, GND, SDA, and SDL pins on the board. 400khz fast mode may work on Wii clones
here is another clone. you have two options for wiring up the board; one cutting traces, the other without cutting traces.
Drotek 10DOF IMU:
WITHOUT LLC: http://www.drotek.fr/shop/en/36-imu-...-pressure.html
Simply connect as in the picture, enable the pullups on the board with the solder bridge(or dont solder them and use Arduino internal pullups). make sure VDD is connected to 3.3v NOT 5v! 400khz fast mode is supported
WITH LLC: http://www.drotek.fr/shop/en/41-imu-...-pressure.html
Simply connect as in the picture, enable the pullups on the board with the solder bridge(or dont solder them and use Arduino internal pullups) Connect VDD straight to 5v 400khz fast mode is supported. define the drotek IMU in the config code
SIRUS IMU: http://multiwiicopter.myshopify.com/...sor-board-3-3v
IMU GND -> Arduino GND, SDL -> SDL, SDA -> SDA, +3.3v to 3.3v supply
enable internal pullups on the arduino. 400khz possible. define ITG3200, BMA180, BMP085, HMC5883 in the config code.
Give short description of your IMU and i will add it.
Jan 20, 2012, 09:26 PM
Should be helpful. So top of pic is forward or right of pic is forward?
Jan 21, 2012, 01:07 AM
Emress
i forgot which way it was in the gui( i havent built my quad yet, waiting for parts).
i added drotek's IMUs and Wii boards. please let me know if anyone sees any issues with the information.
Jan 22, 2012, 02:29 PM
Emress
the left side of the IMU(in this picture, the pin side) is forward
Discussion Do you need help with setup or have questions about the KK, or quadrino. Look here!!! tc3wins Multirotor Drone Talk 30 Nov 20, 2011 10:18 AM
Discussion I want to know how and need some help on upgrading motor in PZ T-28 skarface Parkflyers 5 Nov 07, 2011 07:28 AM
Idea Want to reborn your old foamie ? Come here ! bell x1 Foamies (Kits) 17 Aug 28, 2011 02:18 PM
Here's how you know when your PC.. DNA Life, The Universe, and Politics 10 Oct 29, 2001 09:48 PM
