Thread Tools |
This thread is privately moderated by RMCCOR7737, who may elect to delete unwanted replies. |
Trader Rating: 0
Sold
Hobbico NexSTAR 46 Trainer ARF .46
Hobbico NexSTAR 46 Trainer ARF .46 for sale $300.00.
Can get radio that came with it if needed. Channel 46 You can review all the info on it Here: http://www3.towerhobbies.com/cgi-bin...=LXEXK2**&P=ML Also the caddy below with all the accessories for an additional $100.00. SPECS: Wingspan: 68.75" (1746mm) Wing Area: 722 sq in (46sq dm) Weight: 6.5lb (2930g) Ready To Fly Wing Loading: 21 oz/sq ft (63g/sq dm) Length: 56" (1420mm) Airfoil: High-Wing Center of Gravity: 3-3/16" (81mm) forward limit 3-9/16" (90mm) aft limit from the wing's leading edge at the fuselage sides Control Throws- Elevator: Up & Down ½" (13mm) Rudder: Right to Left ¾" (19mm) Ailerons: Up ½" (13mm) Down 3/8" (9mm) Degrees Incidence: Engine Thrust: 5° right Stabilizer: 0° Wing: -2° |
Reason: Priced reduced.
Trader Rating: 0
Hobico NexSTAR 46
Does the plane come with the radio and training CD? Is this Local Pick-up?
Trader Rating: 0
I will have to look around today for the CD and radio. I do believe I have it somewhere. I have been using my Futaba T6EXP radio on this plane for the last two years. If I cannot find the box that it shipped in, then yes, LPU.
Thread Tools | |
Similar Threads | |||||
Sold | Hobbico NexSTAR .46 RTF Nitro trainer w/1 flight $225 OBO | RChelisrule | Aircraft - Fuel - Airplanes (FS/W) | 4 | Jan 05, 2012 05:17 PM |
Sold | Hobbico NexSTAR .46 RTF Nitro trainer w/1 flight | RChelisrule | Aircraft - Fuel - Airplanes (FS/W) | 1 | Jan 01, 2012 08:04 PM |
Sold | New New Assembled Hobbico Nexstar Select 46 Trainer RTF | rcfunhouse | Aircraft - Fuel - Airplanes (FS/W) | 4 | Apr 19, 2008 07:54 PM |
For Sale | Hobbico Nexstar Select 46 Trainer RTF with anticrash technology! | jadamian75 | Aircraft - Fuel - Airplanes (FS/W) | 0 | Apr 16, 2008 12:33 PM |
Sold | NIB Hobbico Nexstar .46 size trainer | Steve H. | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jun 29, 2007 12:15 AM |
