Jan 20, 2012, 10:53 AM
miniphase's Avatar
Originally Posted by Stuart annat
B&Qfoam?
lovely stuff to work with !
Jan 20, 2012, 10:55 AM
Everything's A Composite
Knoll53's Avatar
This fascinating. Your method is quick.
Your method is so much different than mine (all learned from Phil Barnes's DVD). You have simplified the worst part about foam core cutting, making the templates. Those templates must be somewhat stiff. You say that they are zinc plate but here in the US the litho plates ARE aluminum and very thin. Our litho plates would be too thin to be workable....or maybe I should just try it.
I like your weights. Do you have an overhead crane to move them about?
Kent
Jan 20, 2012, 11:01 AM
miniphase's Avatar
Hi Kent, the litho plate is pretty thin stuff but it works for me.
There are many different ways to skin a cat and the two template method has several advantages over my system, but like I say I'm just plain lazy!
No crane yet, might need one in my old age though.
Jan 20, 2012, 11:34 AM
Knoll53's Avatar
There is a fine line between lazy and smart. I do wonder how you'll manage the start and stop process when cutting. The video is an early attempt (all of mine were) at a hands off cutting method. From the looks of your bow, I'm thinking that my wire should be tighter.
Kent
Hot Wire Foam Cutting - Bottom Cut (0 min 54 sec)
Jan 20, 2012, 01:22 PM
miniphase's Avatar
Here's me cutting a wing a year or so ago. I usually just rest the wire on the trailing edge of the template and switch on, sometimes it needs a nudge to get it going. If I get one side lagging behind I just slow the other side a bit with my finger. The wire pops out the end and onto the board, I wipe off the residue and switch off, flip the core and do the other side.
foam wing cut (0 min 49 sec)
Jan 20, 2012, 01:28 PM
miniphase's Avatar
...anyway cores are cut, and with a little light sanding they'd be good enough for bagging with glass straight onto the foam, but I don't want to turn up to the slope with another pink wing so the obechi is on order
4 1/2 hrs to get to this stage
Jan 20, 2012, 01:47 PM
Knoll53's Avatar
So just to put things together....with the single template you must cut on top of the template, so you flip the foam block over to cut the other side.
Also, you start cutting at the TE which has the template flush with the foam block, so you hold the wire on the template the hit the juice.
Is that about right?
Kent
Jan 20, 2012, 01:56 PM
Vernon Hunt's Avatar
Paul,
You're making fast work of the new wing.....It looks good. It's funny we take totally different aproaches to cutting wings, but that's what makes this a great hobby. I am looking forward to the first flights. Keep up the good work!
Vern
Jan 20, 2012, 02:01 PM
miniphase's Avatar
Yes that's right Kent. All you need is a mm or so of trailing edge template to sit the wire on before switching on the power. I have used a few pins in the past if I can't get the wire to sit. Just stick the pins in the foam at an angle, sit the wire on and hit the power.
As you mention you must cut on top of the template.
From your video the temperature of your bow looks spot on judging by the angel hair, I would only tighten it if you're getting wire lag in the middle.
Paul
Jan 20, 2012, 02:04 PM
Knoll53's Avatar
Swept Wing
Although this is a swept wing, I see from your drawing in post #5, that the cores are cut with square ends. This should simplify cutting quite a bit. So are the root and tip ends cut square too then trimmed later?
If the template is placed square to the sweep, then you must be modifying the airfoil for the template so that you get the properly airfoil at the sweep angle. Is this correct?
Kent
Jan 20, 2012, 02:06 PM
miniphase's Avatar
Originally Posted by Vernon Hunt
Paul,
Vern
Thanks Vern, I find it really interesting to see how other people work too. I spent too many long hours in the dark back in the days before the internet, but since things have opened up I've come across many tips and ideas to speed up the building process.
I'm planning to make the first flights off the slope. I'm making a small pod in the first instance, and then a larger one to house the lipo and motor if I'm happy with light lift the performance.
Jan 20, 2012, 02:11 PM
miniphase's Avatar
Kent
Well spotted Kent, yes I squash the aerofoil along it's length in AutoCad before printing so that when I trim the root and tip, I get the true 'foil.
I think there is some contention as to whether or not this is the correct approach, and on any swept wing you get some spanwise migration of the airflow anyway.....but I'll leave the theory to others and get on flying my models
Jan 20, 2012, 02:30 PM
Knoll53's Avatar
I'm always looking for good examples for using Rhino 3D and this maybe one of them.
In Rhino, you can create a wing surface with the airfoil pointing into the air flow then cut sections square to the sweep to get a perfect template. Not all NURBS modelers will produce an accurate surface, but Rhino does.
Scaling the airfoil, in the X axis, in a 2D CAD package should work as well, but to be honest, I'd have to think about it a bit more to be sure. Upon first inspection, it appears to be a linear relationship. The wing twist may make this a bit more interesting and maybe too academic too.
Just thinking out loud.
Kent
Jan 20, 2012, 03:23 PM
miniphase's Avatar
I have a sneaking suspicion my method may be too simplistic, to be honest I've never checked the aerofoil once I've trimmed the root and tip
Jan 20, 2012, 03:49 PM
internet gadfly
nmasters's Avatar
That's not really necessary. On a high aspect ratio airflow sees the pressure distribution perpendicular to the leading edge. There quite a few threads about sweep effect in the modeling science forum
Discussion 3.2m thermal 'wing miniphase Flying Wings 66 May 05, 2019 12:40 AM
Sold UK - Valenta Espresso 2-metre slope soarer Hogster Aircraft - Sailplanes (FS/W) 3 Jun 16, 2012 03:56 AM
Sold Passer 1.8m Slope/Thermal Glider Kit *NEW* **3 Colors Available** SOS-TopGunsBro Aircraft - Sailplanes (FS/W) 10 Aug 02, 2011 02:18 PM
Rave The Golden wing is a 60" forward swept wing for thermal/light air slope. kylekroker Flying Wings 47 Oct 17, 2008 10:37 PM
