This thread is privately moderated by phil alvirez, who may elect to delete unwanted replies.
Jan 17, 2012, 10:17 AM
amps or volts on ultra-micros
to be or not to be...amps or volts. my point of view.
when increasing diameter or pitch, we reach a point when the motor stops. we can't reach the max rpm's.
now, as long as we don't exceed the limit of the motor and/or esc, if we increase the current, or the voltage, the motor may keep up with that prop.
to increase the current we need to increase the cell/battery capacity (size).
to increase the volts, we need to increase the number of cells-or in the case of single cell systems, use a voltage booster.
the choice is ours. both possibilities have their pros and cons.
for ultra-micros, for amps increase, the change from 160 to 240 means a gain of 2.5 grams (or 4.5 if 360).
if we choose volts increase, the voltage booster adds 3 grams.
going into 240 amps cell seems the simpler way, as it only requires switching the cell.
with the booster it requires replacing wires and connectors (and takes the space for the booster) and there are power looses, as John mentioned.
but if the rx requires an increase of voltage to operate properly, then this is the way.
comments are welcome. may be more points-pro and con for each possibility.
Sold DC Watt Meter, Checks Volts Amps and Watts 3.3 - 50VDC Mahu Aircraft - Electric - Power Systems (FS/W) 0 Nov 30, 2011 05:35 PM
Build Log SLOGGER-1, servo volts/amps/pulse logger Inflexo Radios 0 Nov 01, 2011 06:03 AM
Help! Of Amps, Volts, and Watts! rotorblade400 Large Electric Helis 4 Apr 30, 2011 04:05 PM
Help! Of Amps, Volts, and Watts! rotorblade400 Electric Heli Talk 5 Apr 28, 2011 09:15 PM
best solution amps or volts anatak Power Systems 14 Apr 27, 2003 04:14 PM
