LiPo Battery Flighttime with MultiWii - RC Groups
Jan 14, 2012, 09:49 PM
Hi there
I have a Zippy 3000 mAh 3S1P 40C battery (weight: 270 grams = 9.52 oz)
They were ment for the Suppo 2212/13 Motors, but since I'll be using other motors and esc's is it bad to have such a powerful 40C battery?
I'll have this:
The weight should be not a problem, but is it bad if you have such a high discharge rate for those 10A motors?
If yes, what do you suggest me to do?
If not, how long will I be able to fly ? +-
Thanks a lot people!
Jesse
Jan 15, 2012, 12:13 AM
drcigg's Avatar
The battery will work just fine
Jan 15, 2012, 12:51 AM
40c only refers to the MAX discharge that it is capable of. you could run that batt at 0.1 C until it was discharged and it would be just fine. When you vary the throttle you are effectively varying the rate, power, at which you use energy stored in the battery. so no problem using a 40c capable batt. the only downside is that its heavier than necessary. that batt can sustain 120A. but i bet you dont need nearly that much. as far as runtime, it depends on weight of craft. most typical is 1000g. if your power system is 10g/W efficient that means you need 100 W to hover. since your batt has 3*3.7*3 watt hrs of energy. you could fly for up to 19 min or so. in reality there are other losses. i had mine on similar batt fly for 16 min.
Jan 15, 2012, 05:30 AM
thanks!
wow thanks. Looks promising.the quad weights 770 gr
Question Looking to Replace Battery with a Lipo badcrc32 Electric Power Cars 4 Dec 31, 2011 04:10 PM
New Product 2S-3S LiPo Battery Monitor with integrated LED switch maglite DIY Electronics 20 Aug 17, 2011 11:43 AM
Discussion Best Lipo battery with a high charge rate? RICHF16 Batteries and Chargers 2 Mar 24, 2011 07:16 AM
Sold Zippy 240mah 1S lipo with PZ battery leads, NEW. $7.00 shipped CONUS nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 21, 2011 06:11 PM
Discussion Shorter flighttime with a 3s Lipo, than a 2s Lipo ? SpookiePower Batteries and Chargers 12 Oct 28, 2009 03:19 PM
