Jan 11, 2012, 04:32 PM
Tim B.'s Avatar
Build Log
Dumas 36' Motor Life Boat #1258
I have started to build a Dumas model of a 36' Motor Life Boat.
I have been working on glass hull Tugs, this will be the first woode hull boat I have built that will go in the water.
There is another thread, a discussion, which lead me to have the interest to do this build ( hope I did the link correctly ).
https://www.rcgroups.com/forums/show....php?t=1518107
There is an actual boat not far from me, I hope to visit to get pics ( Lifeboat station at Point Reyes, California ).
The plans are outstanding, several sheets, two seperate instruction books, one text and one pictorial.
UPS done good, no damage at all ( see inpection performed by my helper ).
Jan 11, 2012, 05:04 PM
Gravman's Avatar
At last we can see one getting built. Very good photo's. Dumas does offer motor and drive train parts as extras but not needed right now. With the help of your Inspection
Foreman you should be well on your way.
Latest blog entry: Myrtle Corey
Jan 11, 2012, 05:07 PM
r/c ships and workboats
lazer cut parts look good and all seems to be fitting quite well there Tim.
Jan 11, 2012, 06:16 PM
Tim B.'s Avatar
Planning ...
Hi Gravman, see page 5 of your original post, I have a nice little gearmotor from MACK, I need to make a mount etc. before I get a coupling and such wich will get me final dimensions.
I think I better do that before I lay to with plank.
Jan 11, 2012, 06:17 PM
Tim B.'s Avatar
Nice kit
Hi Keith, yes, the parts in this particular kit came ot razor sharp and trouble free, just a bit of sanding and they went down.
Jan 11, 2012, 06:39 PM
Tim B.'s Avatar
After lunch
A few more ( finished lunch ), time to show the sheer work.
The sheers are three peice, in retrospect I shooda cut my own single piece parts so there would be no trouble...
Even though these cured overnight, they were ready to snap as I was putting them in.
Used hot water and a dropper at edge to releive tension, it worked well, slowly worked them in.
Put in braces on the first side for strength so I could keep moving.
Jan 11, 2012, 10:06 PM
Originally Posted by Tim B.
Slow, steady power.
Yep, that's a nice little unit. I run one in my Monterey- it will be perfect for this boat. On 7.2v, I have the throttle epa turned down a little for scale speed and it runs all day long on a 1500 pack.
Jan 11, 2012, 10:45 PM
Tim B.'s Avatar
Speed
This one came with three different gears for three different ratios ...
Jan 11, 2012, 11:29 PM
FROM THE MIND OF A MADMAN
gpzy's Avatar
Great looking boat !! Thanks for posting the build !!!
Jan 11, 2012, 11:51 PM
Taking care of the pond.
MILLERTIME's Avatar
I'm watching this build.
Jan 12, 2012, 12:11 AM
KC8WPF
CG Bob's Avatar
When I purchased my kit, I also purchased the Dumas running hardware kit for it. I plan on using a MACK Products SB-4 stuffing tube and a right hand pitch prop. The Dumas hardware kit has a left hand pitch prop. I plan on using parts of the Dumas stuffing tube to make up the rudder stuffing tube.
The MACK SB-4 is 5/16" OD, and requires trimming 1/16" off K3 and K4 and possibly modifying Frame 7 to fit over the stuffing box.
Jan 12, 2012, 12:49 AM
Yep.
Jan 12, 2012, 10:44 AM
Tim B.'s Avatar
A fine plan !
YOUR plan sounds good !
Happen to have the SB-4 tube assy ( bought it with the gearmotor and prop above ), you guys have been doing this a long time, thanks for being patient and throwing in, that's why I value being a member so highly.
I want to get the design and dimensions of the motor, shaft, servo and battery location established before I plank.
And ballast !
With all this balsa, this thing is going to float like a packing peanut !
Jan 12, 2012, 10:46 AM
Tim B.'s Avatar
Hi Manny
Morning Manny !
Good to see you are there.
I got so focused on your Shelley I had to step back and find a distraction, this is it !
Jan 12, 2012, 11:02 AM
Tim B.'s Avatar
Mailbox
Yep.
Captain !
Your mailbox is full....
We kenna send you any more messages to ye 'til you purge !
Mini-Review Dumas 36 ft Motor Lifeboat Gravman Scale Boats 72 Apr 15, 2021 12:00 PM
Discussion 36 motor life boat WAXER128 Scale Boats 6 May 07, 2012 12:38 PM
For Sale Dumas 36 in. Chris Craft Runabout Boat Fastandlow Boats (FS/W) 4 Jan 04, 2012 09:25 PM
Discussion USCG 36500 36' Motor Lifeboat dumas hazegry Scale Boats 17 Sep 27, 2011 10:58 PM
Sold Coast Guard 44 Motor Life Boat RC Dumas #1203 Boomer1 Boats (FS/W) 4 Nov 11, 2010 11:12 AM
