Oct 20, 2019, 05:33 PM
old4570's Avatar
2.5 Diesel
Webra Mach 1 copy ..
A very popular engine for some reason .
Quite a few variations , so I have to wonder if they were made by more than one group .
Oct 31, 2019, 11:22 PM
My Class 1 Speed OS CZ 11PS engine and pan setup. Engine is actually 1.8cc I believe. Single bladed CF "Joe Supercool" prop. Engine runs at about 34K rpm in the air. Rules required a symmetrical model with two lines. Dolly is a standard Stab lock A size.
Nov 01, 2019, 08:10 AM
UAS Pilot - FAA# *******HRK
CryHavoc's Avatar
McCoy .35 Hybrid stunt engine.
It's an old RedHead "Lighting Bolt" crankcase that I bored out a few thou to take a Testors/McCoy series .21 Blackhead cylinder and ringed piston. I also added is a Bjorn Baal piston ring and a SuperTigre style needle valve.
Nov 01, 2019, 08:45 AM
Some flying visitors examine an Enya .15 Diesel mk2 assembled from parts from Enya Direct a few years ago. Engine now runs very strongly and the birds still turn up most days for a piece of meat.
Nov 01, 2019, 08:52 AM
old4570's Avatar
I have a Enya Mk1 and Mk2 myself ..
Only run the MK2 , but yeah , a nice engine ..
Not bad for 1960 was it ? ( MK2 )
Nov 01, 2019, 01:56 PM
Gluehand's Avatar
A couple of early "pre-Redhead" Duro-Matic McCoys, called Super Stunt or just Stunt......
Well made...!
Nov 01, 2019, 06:00 PM
I've got a mk1 in bits, I really should try putting it back together. Otherwise two newish mk2's. More powerful that a mk3 Olly in 1960, less economical but you could buy them across the counter. The Olly was more expensive and you had to wait up to 18 months. I think Adrian Duncan suggested that the Enya was a big influence on Super Tigre and MVVS.
Nov 01, 2019, 06:50 PM
old4570's Avatar
Hmmmm , ST already had the G20s was it ?
But yeah , that MK1 was winning some comps in it's day if memory serves .
The MK2 is just so much heavier ..
Dont recall the MK2 being as winning as the MK1 ?
The the G20/15 came out about the same time as the MK2 Enya 15D ...
Pre-production G20/15s came out ? Might have to go over my Aeromodeller collection from around that period to see ...
Been a while since I looked back in time .
Nov 01, 2019, 07:18 PM
The early G20 (circa 1956) I've run had a baffle piston. Yep the mk1 Enya was great, just fragile. Enya may have gone a bit overboard with the mk2 but they are reputably bullet proof. I didn't see a G20/15 flat top piston equipped engine till around 1964-65 or so.
Nov 01, 2019, 09:31 PM
old4570's Avatar
G20/15
Was the 1960 model , then the 65 and then the 70 ..
When the 60 model hit customers ? If my ST mem serves , there were some pre production motors that went to speed and other competition flyers in Italy .
Did these motor leave the factory 59 or 60 ? , production motors I think left the factory maybe 61 , I would have to check those Aeromodeller magazines .
The G20s is the baffle motor ..
Im not sure if some G20s were made without a baffle as they were about to transition into the G20/15 motors .
Nov 01, 2019, 11:15 PM
CryHavoc's Avatar
Well made...!
Nice,
I've never had one of these but I've always been curious how they run.
Nov 02, 2019, 06:14 PM
downunder's Avatar
This is my ST G20/19 in a (different) 1960 case but is baffled and has a 1/4x28 crankshaft, not the usual 5mm, so has no front ball race and probably means it was intended for a car.
Nov 02, 2019, 06:58 PM
downunder's Avatar
Seeing I had my camera out for the ST above, here are my Cox Sportsman and Cox Olympic. The Olympic was the only Cox (of the traditional style) to have a ball raced crankshaft.
Nov 02, 2019, 06:59 PM
I've never seen one of those before. What were they used for?
Nov 02, 2019, 07:03 PM
I used to lust after the Cox Olympic in the glass display case at Levison's Hobby shop in Sydney. Not quite as unaffordable as an Oliver Tiger but very exotic.
Discussion Control Line Team Racer plans and pictures perttime Control Line 429 Aug 23, 2019 12:24 AM
Sold McCoy RedHead .35 control line engine $20 shipped revkev Aircraft - Fuel - Engines and Accessories (FS/W) 2 Nov 08, 2011 12:39 AM
Sold OS-40-FPS, Control Line Engine "New" $80.00 Shipped! 1stGeppetto Aircraft - Fuel - Engines and Accessories (FS/W) 4 Oct 17, 2011 11:38 PM
Sold NEW in the box OS Max 46LA-S control line engine [email protected] Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 18, 2011 03:45 PM
For Sale o.s .19 control line engine i-fly-any-and- Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 31, 2011 04:45 PM
