This thread is privately moderated by herk1, who may elect to delete unwanted replies.
Jan 05, 2012, 07:39 PM
Herk pilot emeritus
herk1's Avatar
Build Log
Micro space shuttle chuck-glider conversion
This tiny 12-inch-long foam chuck glider (link) seemed perfect for conversion to RC using micro components.
My first idea was to use the "brick" ESC/RX/servo unit from one of the Horizon micro planes. So I cut off the top from the Shuttle with a hot-wire, dug out some room, then transfered the "brick" and motor/gearbox from a Hobbyzone Champ to the Shuttle...adding Depron elevons onto the rear of the shuttle for control (see first photo below). Unfortunately, when I test-flew this configuration, the Shuttle could only manage a controlled descending glide to the ground. Apparently the Shuttle needs more speed to fly than the rather low-pitch-speed power setup of the Champ provides.
But I'm not one to give up after a single try. For my second try, I ordered one of those tiny new micro-size Spektrum-compatible receivers from HobbyKing (it weighs only 2-grams), and some tiny 1.7-gram servos to go with it. Then I stripped another micro plane in my hangar of it's high-RPM 5-gram brushless outrunner motor and 7-amp ESC. For a battery, I chose the smallest 2S LiPo that I have -- a 200 mAh one.
This new configuration surprised me with the dramatic difference in flight properties. Now the Shuttle climbs strongly at full power (almost too strongly in fact...it seems as though a thrust angle adjustment may be in order). The Shuttle even cruises along happily at only half power. The only real problem on the remaiden was the touchy roll rate, because I still had on the big "paddles" for elevons that I had sized for the slower original configuration, and excessive throws to boot.
Jan 05, 2012, 08:52 PM
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
Nice Job!
They did this conversion in one of the magazines a year or two ago, and I have been looking to do the conversion ever since. Yours turned out beautifully
Discussion Space Shuttle Enterprise - Part II - with flying ET Hepdog Foamies (Scratchbuilt) 35 May 01, 2015 01:56 PM
Discussion Space Shuttle / 747 separation k3d Scratchbuilt EDFs 52 Dec 27, 2011 10:53 PM
Discussion Air hog Titan Rc Conversion (Brushless) Chuck Glider *VIDEO* somtimes Foamies (Scratchbuilt) 0 Sep 11, 2011 05:27 PM
Discussion Guillow's Space Shuttle Orbiter Conversion MinneFlyer Scratchbuilt Indoor and Micro Models 8 Jan 11, 2009 12:03 PM
Discussion Space Shuttle rocket glider bwolfe Rocketry 18 Aug 09, 2006 07:40 PM
