Jan 17, 2013, 04:01 AM
Advanced Monkey
nebstress's Avatar
Originally Posted by vili
Then what is this?
https://www.hobbyking.com/hobbyking/s...dProduct=31135
It also has an eeprom.
Its a GPS Module (with an eprom)
[EDIT]
Its a clone of the V2 with a smaller antenna & slightly different firmware.
Jan 17, 2013, 04:39 AM
What beeper I can use for replace original beeper?
Jan 17, 2013, 05:19 AM
Oops. Will it work with rabbit or aiop?
Is it much worse than v2? Maybe as good as original LF gps?
Jan 17, 2013, 05:35 AM
Advanced Monkey
nebstress's Avatar
Yes it should be fine with the Rabbit, it just has a slightly smaller antenna than the V2 & LF GPS & a different Baud (but still compatible), it was really setup for AIOP (MegaPirate) & Arducopter.
It has exactly the same 'U-blox NEO-6M' chip/module as the V2 & LF.
Jan 17, 2013, 05:43 AM
Advanced Monkey
nebstress's Avatar
Any 5v beeper should be fine but I have heard that it is hard to find one quite as loud, I have even seen people replace the beeper with an LED.
Jan 17, 2013, 06:00 AM
I use the beeper for desktop PC, it is as loud as the rabbit fc beeper.
Jan 17, 2013, 07:02 AM
Need beeper with sound generator inside?
Jan 17, 2013, 07:53 AM
Then why V2 is better than LF? See more sats, more stable the copter?
My question is simple: i have LF, but ordered the V1 for better precision.
Was this a bad idea, or V1 is still better than LF?
Jan 17, 2013, 08:13 AM
Advanced Monkey
nebstress's Avatar
The V2 has better firmware than the LF.
There are no V1's available, they were replaced by the V2 months ago!
If you are referring to the "HobbyKing NEO-6M GPS Module" that is not a V1.
The HobbyKing NEO-6M GPS should work as well as the LF GPS.
Jan 17, 2013, 12:38 PM
deleted
Jan 17, 2013, 01:05 PM
Advanced Monkey
nebstress's Avatar
You can use with rabbit my new NEO-7N board
-+-SPAMMER-+-+-SPAMMER-+-+-SPAMMER-+-+-SPAMMER-+-
Why on earth would anyone even consider that when the best module for the Rabbit is only $25.(inc.shipping) & does come with the cable & is plug & play
Go & sell your wares somewhere else!!
Jan 17, 2013, 02:43 PM
So, not better? My order was useless?
Jan 17, 2013, 02:46 PM
Advanced Monkey
nebstress's Avatar
You will have to try it & see, it might work better for you, you will have to let us know how you get on with it.
Jan 17, 2013, 07:03 PM
From what I understand, if you assign a switch to both AutoStability and 3D Stunt mode at the same time, Rabbit can perform auto-flips. If so, what causes it to flip in any direction? Does moving the ailerion or elevator stick to a full extent initiate the flip?
Jan 17, 2013, 09:04 PM
It started with a red biplane
tony3di's Avatar
I tryed once to connect a led directly to the beeper outputs and couldnīt get it to work. Do you know the correct way to do it? A little tutorial would be nice.
Discussion Free Flight FF Auto Balance Controller with 3D Acceleration Sensor For QuadCopter C team MOD Multirotor Drone Electronics 5806 Mar 30, 2019 03:48 AM
Discussion Multicopter Flight Controller Comparison Chart mbsteed Multirotor Drone Talk 27 Jun 13, 2015 09:41 AM
Discussion New quadcopter frame only (compatible with KK/MK MultiCopter Controller ) udoor Multirotor Drone Talk 23 Aug 07, 2011 12:05 PM
Sold FY90Q Flight Controller for Quadcopter - $70 shipped jpsabo Aircraft - Electric - Multirotor (FS/W) 1 Jul 29, 2011 10:21 AM
For Sale Complete MultiWii Quadcopter Flight Controller Kit madushan2008 Aircraft - Electric - Multirotor (FS/W) 7 Jul 26, 2011 08:58 AM
