Oct 03, 2003, 11:06 AM
Question
Diesel Fuel
Anyone know were diesel fuel can be obtained in Canada. More specifically Southern Ontario.
Regards Frank(Ollie) W.
Oct 03, 2003, 11:30 AM
Ask your local hobby shop to get some in or buy from Davis: http://www.davisdieseldevelopment.co...uel-tubing.htm
Oct 03, 2003, 11:36 AM
Tony Oliver's Avatar
Make your own if you can get the ingredients.
A good mix is 50% paraffin (kerosene) 20% Castor oil and 30% Diethyl ether (pharmaceutical grade). These are measured by volume, but are not critical. You can equally use 1/3 of each. Up to 2.5% of amyl nitrate will help as an anti-knock agent but not essential.
Ether is the problem and you need to ensure that the seller is aware it is for model fuel use.
Tony
Discussion fire ext suggestions and fuel suggestions diesel/jet-a horsefeet Jet Turbines 25 Feb 24, 2017 10:40 PM
Discussion Diesel fuel residue and plastic film ...? AlphaWhisky Vintage & Old-Timer Designs 5 May 16, 2016 10:32 PM
Help! Diesel Fuel UK Chris Jenkins Vintage & Old-Timer Designs 11 May 01, 2016 10:33 PM
Sold Dave Brown Six-Shooter fuel pump-Gas/Diesel only jbrundt Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 16, 2016 08:56 PM
Sold Dave brown gas/diesel fuel pump tkimbro55 Aircraft - General - Miscellaneous (FS/W) 1 Oct 04, 2015 10:29 PM
