FY30A with multirotor firmware - RC Groups
Dec 24, 2011, 11:56 AM
the plane stabilizer FY30A from feiyu tech can now also be used for multirotors.
according to the manual it works for tri, quad + and quad x atm.
i tried it with quad x.
fy30a: http://www.feiyu-tech.com/product-en.php?id=13&mlist=3
firmware and manuals: http://www.feiyu-tech.com/download_list-en.php
video of testflight.
fy30a // multicopter fw 1.20 (2 min 37 sec)
it works pretty good. but i dont got it tuned as stable as an aq50d pro or precise in acro mode as an mwc. but its as simple to setup as an kk board [3 pots] with an additional selfleveling mode which can be switched midflight with ch5. so its more or less the same as the FY90Q pro.
has anyone else already used this stabilizer for a multirotor?
Dec 24, 2011, 12:55 PM
Tri-Quad-Hexa-Octo-copters!!
Looks good Markus. Is there a Parameter Setting utility for the FY-30a?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
Dec 24, 2011, 02:23 PM
Cheers,
Jim
i tried the fy90q pro setup tool and could read/write parameters...
Dec 26, 2011, 07:53 PM
another flight from today..
fy30a // multicopter fw 1.20 [2] (2 min 44 sec)
Dec 27, 2011, 03:57 AM
vtol fan
nadine's Avatar
Hi warthox....nice work!
where did you buy,exactly, the flight stabilizer FY30-A????
Dec 27, 2011, 04:36 AM
nadine, lascia perdere..
you are better off with an AQ50D Pro.
This product will probably be ready in one year...
Dec 27, 2011, 08:22 AM
http://www.fpv4ever.com/lang-en/stab...es-fy-30a.html
or
http://www.immersionsflug.de/FY-30A-...sierung-3-Achs
Jan 10, 2012, 06:40 AM
Firepower
Firepower's Avatar
Just wondering what is the best to buy for a quadcopter:
FY-90Q PRO or a FY-30a.
Is FY-90Q PRO getting a bit old? I am not sure.
Also there are two versions of the FY-30a. Just wondered what the difference is?
Jan 13, 2012, 01:33 PM
vtol fan
nadine's Avatar
Usb ttl cable
Hi,warthox.What cable TTL did you use for trasfer the code for quad in fy30-a,plastic case version?!
I know that with the plastic case version,we d'ont have inside box USB TTL cable...
Cheers
Jan 13, 2012, 01:41 PM
vtol fan
nadine's Avatar
Usb ttl cable
Oooops.....double post.....
Jan 13, 2012, 01:44 PM
Cheers
i used the usb ttl cable from fy.
Jan 14, 2012, 03:48 AM
vtol fan
nadine's Avatar
So,you mean ,all two version,plastic orange case and alluminium black case,both of them in the box we will find the TTL cable in!????
cheers
Jan 19, 2012, 10:21 AM
go ahead and try
Having trouble downloading the ttl driver from Feiyu web site... keep getting this message: http://www.feiyu-tech.com/uploads/en...0114164556.rar
Can someone send me a copy: bikeoffthegrid@gmail.com... Cheers!
Jan 19, 2012, 11:20 AM
go ahead and try
got the files.... proceeding to update firmware as per instructions!!! I hope this works!
Jan 19, 2012, 11:53 AM
go ahead and try
Firmware update successful!!! Testing system....
New Product FY30A Stabilizer with upgradable firmware,camera mount stabilization feiyudz FPV Equipment 487 Oct 23, 2014 07:46 PM
Discussion XAircarft X650V Multirotor with new firmware 1.33 Promotional Tester needed bdpowers Multirotor Drone Talk 13 Sep 18, 2011 05:43 PM
Discussion XAircarft X650V Multirotor with new firmware 1.33 Promotional Tester needed bdpowers Multirotor Drone Talk 0 Sep 09, 2011 01:16 PM
Discussion Who can write firmware to make heli flybarless controller for multirotor? helisfreak Multirotor Drone Talk 1 Jan 26, 2011 01:22 PM
