The ORIGINAL #16 HD keycam thread (read posts #1-#5 BEFORE posting questions) - Page 1325 - RC Groups
May 15, 2018, 09:42 PM
ultra cheap pilot
ican3d's Avatar
Originally Posted by Noize
Hi, folks! Need help! My 808 #16 is turning on with solid yellow after red, then doesn't react on any buttons, can't record, can't switch mode, only reset button is working. PC is not recognizing camera at all. Trying to manual upload new bootloader and firmware with no result - same issues. Is it dead?
I own about 12x unit of 808 #16 where 5x of them have the same problem like yours after several usage especially if the lens module knocked hard, i solved it by replacing the lens camera module because some parts of the ribbon connection behind the camera lens module is loose or damaged. Try apply pressure behind the camera module's metal panel where the ribbon is and activate. Sometime the camera module is overheating else check the ribbon connection.
May 20, 2018, 11:45 PM
Wow, 12 units are much! You were right ribbon connector issue. Thanks
Discussion Looking to buy #11 HD Key Cam within US Abolfazl Aerial Photography 4 Mar 20, 2016 12:14 AM
Discussion The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) Tom Frank Aerial Photography 9936 Feb 11, 2014 09:56 AM
Poll Poll For Current and Future #11 HD Key Cam Users Tom Frank Aerial Photography 0 Sep 25, 2011 11:55 PM
Discussion New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! Jaybee Aerial Photography 4 Jun 02, 2011 11:39 AM
