The name has a typo... it's eletoponline365, the China direct seller named in the up-front InfoPost #2. They do not list spare batteries on their web pages, but they supply the batteries to every verified re-seller as well as selling them direct if you email and ask.
Try a name brand CL4 card formatted in the camera and see if it cures the issue. If loop records starts there is nothing in the settings that would cause it to stop randomly other than files that are tagged as read-only and will not be over-written by the camera. |
I can safely say that all my problems (randomly shutting off, taking pictures while shooting video) are heat related.
Also, if it sits in the sun for a while, the image gets blurry. (I have to stress that in the sun sits just the lens/sensor assembly because I am using an extension) I don't think it gets out of focus because the lens is friction fit and the sensor's sqare body "sits" on a flat surface, so neither of them can move. But the heat somehow still messes it up. I disassembled all of my setup from the car and brought it inside, and it works fine here. No pictures, no shut off, no blur. It's not even that hot here (~20 C) Very very disappointed. Thanks for everyone that tried to suggest solutions. I guess the #16 is not really suitable for a DVR. At least, not a hard-wired one. |
Hit a tree today, which dislodged my 808 V3. Done that before without problems, but this time I can power on the camera, but can't get a blinking yellow record light . Looks like the process stops at power up. Looking at the circuit board under a magnifier does not reveal any apparent problems. Reset does nothing. It's been a good camera over many many flights, but is this the end of a good relationship??
If still no Joy, you may have a cracked solder connection. There are dozens of them under the DSP chip that cannot even be inspected. If that is the issue, you could try the risky last ditch "oven bake" procedure to reflow the solder connections. This has worked for a few Mobius users (see here). |
Update. It's dead. The lens and ribbon assembly is good, as is the battery, so some spares for the new one. It was a great camera with well over 200 flights (and the odd high speed crash!) under it's belt - mainly on racers and big EDFs. Use a Mobius for the warbirds etc.
I think my camera might be broken. I'm noticing two things that are inconsistent with the instruction manual
#1 When I plug my camera in to charge the LED is red. The manual says it should be green. #2 When I go to power on my camera I hold down the power button for 2 seconds and the LED goes from red to yellow/orange and then shuts off. Any ideas? Did I purchase a bad camera? Thanks. |
Comments below in Green...
I had a crash with my plane and since then the yellow light comes on but will not flash/record. Neither will it give me video out for FPV use. I wanted to see if an update might help but the computer wouldn't recognise it either. After reading your responses I swapped the lens module for a spare one I had and surprise surprise its all good again |
Thread Tools | |
Similar Threads | |||||
Discussion | Looking to buy #11 HD Key Cam within US | Abolfazl | Aerial Photography | 4 | Mar 20, 2016 12:14 AM |
Discussion | The REAL (#11) HD Key Cam Thread (PLEASE! READ POSTS #1-#3 BEFORE POSTING QUESTIONS!) | Tom Frank | Aerial Photography | 9936 | Feb 11, 2014 10:56 AM |
Poll | Poll For Current and Future #11 HD Key Cam Users | Tom Frank | Aerial Photography | 0 | Sep 25, 2011 11:55 PM |
Discussion | New HD Key Cam CHAMP? 1080x720p 3 HOUR RECORD TIME! | Jaybee | Aerial Photography | 4 | Jun 02, 2011 11:39 AM |
