New Product
HS-5646WP Waterproof Servo - $54.99 - In stock!
Just arrived today!
Brand new Hitec HS-5646WP Waterproof Servo - just $54.99 Hitec’s new waterproof servos have what it takes to keep your radio control vehicle, airplane or robot watertight! With high torque, dual ball bearings and metal gears, this digital waterproof servo has the industry’s first IP67 rating, ranking it among the most durable and reliable servos for wet conditions. Whether you are manning your power boat, bashing in the mud, directing your underwater robot, or water landing your 25% plane, the HS-5645WP will dependably keep your mind at ease! Control System: +Pulse Width Control 1500usec Neutral Required Pulse: 6.0-7.4 Volt Peak to Peak Square Wave Operating Voltage Range: 6.0-7.4 Volts Operating Temperature Range: -20° to +60° C (-4°F to +140°F) Operating Speed (6.0V): 0.20sec/60° at no load Operating Speed (7.4V): 0.18sec/60° at no load Stall Torque (6.0V): 157oz/in. (11.3kg.cm) Stall Torque (7.4V): 179oz/in. (12.9kg.cm) Operating Angle: 45 Deg. one side pulse traveling 400usec 360 Modifiable: No Motor Type: 3 Pole Ferrite Bearing Type: Dual Ball Bearings Gear Type: 3 Metal Gears and 1 Nylon Gear Connector Wire Length: 7" (178mm) Dimensions: 1.65” x 0.83” x 1.57" (41.8 x 21 x 40mm) Weight: 2.15oz (61g) Horns and Hardware included with HS-5646WP servo. Other Features: - Metal Gear with MP First Gear - Dual Ball Bearings - Industry’s First IP67-rated Waterproof Case IP = International Protection Code 6 = Dust Tight, 7 = Immersion up to 1M - 2 Cell LiPo Capability - Programmable Circuit - Standard Size Hitec Spline For more information or to purchase: http://www.servocity.com/html/hs-5646wp_servo.html |
Latest blog entry: Building a Portable Solar Tracking Mount
