Dec 06, 2011, 01:47 PM
Matt_w's Avatar
Help!
Collet or grub screw
I maidened my quad on Sunday and I'm not getting the efficacy I should, even with balanced props I am at 60% throttle to hover. I have notest some osalating in the prop adapters and I am using the grub screw type so as I tighten the screw it moves of centre. Picturing how a collet works it seames they may be better but what are you thoughts?
I brought the wrong motors so I have had to turn the spindle round and fit a collar as they where designed to be mounted from behind, I would like to buy an adaptor that mounts straight on to the motor but I can't seem to find one with 3 holes that doesn't cost more than the motors did.
Question 5mm motor shaft, collet or set-screw prop adapter? CNY_Dave Glow to Electric Conversions 6 Sep 21, 2011 04:02 PM
Help! Prop adapter: collet or screw? Samjet Electric Ducted Fan Jet Talk 2 Sep 13, 2011 06:25 AM
Help! Grub screw removal!! mountainsax Mini Helis 3 Mar 09, 2011 10:47 PM
Question Prop adaptor - set screw or collet? Doubledog Power Systems 8 Oct 08, 2008 08:44 AM
Wanted 3mm Collet or set screw prop adapter micronut Aircraft - General - Miscellaneous (FS/W) 7 May 20, 2008 03:15 AM
