Originally Posted by dr400 Setup issues So I am building my quad and now at the setup. I hav a crius multi wii lite,connected to a ar6200 rx. I set the esc throttle individually through the rx. Plug all esc wires into board to fire it all up along with the signal wires to yaw pitch roll. However all that happens is that all the escs beep constantly with no response to throttle. I have set my atv on my jr radio to 125% and done alot of things just can't get motors to spin when connected through the board. Any ideas? Hey I had issue with both my arduino based tri and my Crius multi wii: I had to lower the trim and I think travel on my throttle way below zero before it would arm. Maybe -20 or 25%. I really like flying my crius SE quad - the poor tri does not get much flight time anymore. Gary Thanks Gary Got it figured lowered th throttle In the code and it arms and works fine. Flew today all was great just some tweaking needed to make it better |
http://www.rctimer.com/index.php?gOo...8&productname= Would be interesting to hear from others if prop failure in mid flight is a common occurrence of not. |
Noob
Hello guys noob question I'm trying to build a quad with my son
We bought crius SE but we need help on how to connect the wires from the board to to the rx is a turnigy 9x 8c v2 we already calibrate each esc with the tx but we need help with the other wires all help will be more than welcome Thank you, |
where can i find v.2?
what could be the problem that the Crius MultiWii board always starts in Mode 1, regardless if i arm motors in Mode 1 or Mode 3?
cannot fly in Mode 1, so thats a serious problem. any hints? thank you best regards Bernhard |
itīs v1.9 i tried it arming Mode 1 and Mode 3, and it always arms with Mode1
Config is: Hexa with serial sum_ppm i tried to change the Channels but it nearly crashed my roof, so i have no idea what to do greetz Bernhard |
Hi guys , looking for some help. trying to work with Crius Serial LCD with the arduino, i can not find what the codes are to:-
A) clear Screen B) set curser position C) set a new line D) Flash Curser Any advice, help or pont me in the right direction for further information would be greatly appreciated |
bones
were you able to find a solution for this issue. i am havinf a similor issue with aux2 none of my sensors wok for aux2 i see in the gui that when i toggle the switch the values changes but even with mag and baro are assigned to aux 2 by toggling the switch i cant switch them on/off. they stay off but when i assign them to aux1 they get turned on/off has anyone seen this before? BTW i have correctly defined (uncommented) the pin12 in the scetch Quote:
Thread Tools | |
Similar Threads | |||||
New Product | Full Foxtech AIO Glasses Review | Guizmo12 | FPV Equipment | 1362 | Dec 13, 2014 08:08 PM |
Sold | Arduino / MultiWii / Megapirates Boards | 3rdeyepro | Aircraft - Electric - Multirotor (FS/W) | 3 | Dec 03, 2011 09:43 PM |
Wanted | MSR 5in1 boards and MCPX 3in boards | beachflyer | Aircraft - Electric - Helis (FS/W) | 3 | Nov 22, 2011 10:14 PM |
Discussion | Foxtech AIO goggles RX? | Teamsherman | FPV Talk | 2 | Oct 02, 2011 10:06 AM |
Sold | 3 x PCB boards for multiwii copter for $28 | madushan2008 | Aircraft - Electric - Multirotor (FS/W) | 1 | Sep 06, 2011 06:53 AM |
