Hi NCMAX
The motor shaft is 2.3mm I don't think you will find a folding prop hub to fit that shaft..I cut 8mm off the shaft end and used one of these .. https://www.hobbyking.com/hobbyking/s...rew_Type_.html
The prop adapter that comes with the Solo is usually off center and causes vibration.. I also changed the ESC to a 40 amp Plush a bit of over kill but it works great... https://www.hobbyking.com/hobbyking/s...ontroller.html I use a 3s1300mah 20c Zippy battery.. https://www.hobbyking.com/hobbyking/s..._3S1P_20C.html Any bigger and you will have trouble with the CG being to far forward.. The solo flies great with the CG at 55mm..The solo is a great plane once it is set up properly .. I have had many hrs of relaxed flying and its defiantly fun to fly..I don't try to hotline it I fly as a nice little glider that it is..If you need any more information don't hesitate to contact me I will be glad to help were I can .. Cheers John.. |
reaching into the grave here... I couldn't find any remnant of bridgeskyrc.com. I'm looking for spare parts for this thing. Anyone?
Thread Tools | |
Similar Threads | |||||
New Product | Nine Eagles Solo Pro 100D / Solo Maxx 3D | Frank_fjs | Micro Helis | 1877 | Jan 20, 2018 12:38 PM |
Mini-Review | HXT 2730-1500 (~1690Kv) and Turnigy R&B 2730-1500 (~1600Kv) | Dr Kiwi | Electric Power Systems | 74 | Sep 19, 2017 07:50 PM |
Build Log | neRecv - Solo/Solo Pro TX as HID Joystick or PPM simulator controller | kile | DIY Electronics | 51 | Jul 09, 2013 06:36 AM |
Sold | Nine Eagles Solo Pro/SOLO/Free Spirit/BRAVO III Battery Charger | palomo | Aircraft - Electric - Helis (FS/W) | 0 | Feb 17, 2010 07:38 PM |
