I'm trying to find the spec as far as diameter etc. for the,
Flyzone Aircore Brushless Motor in there micros , is there a list In this thread, I couldn't find much on a search for it? |
Thank you KH
Recently had reason to weigh the following so here they are:
Hobbyking EPS-7 Gearbox with motor - 3.8g Just wires, no plug. Nominal weight on HK website is 3.6g This is the motor supplied and recommended for use with the new balsa models from Hobbyking; Copernicus, Galileo, Keplar. Hobbyzone HBZ4930 Champ Gearbox with motor - 6.2g includes the motor plug. |
Supermicro Mi-3A 1s BL esc - bare version
Listed on HK as 0.36g Tried to weigh it on my scale (0.1g resolution) got 0.4g |
Was looking for something like this thread, hope it is made into a "sticky". Wish list of US suppliers could be correlated with these items. Many items may not be available in US.
The micro model builders niche is a lot larger than I realized. My electric powered RC models are have grown to .40 sized but am becoming interested in converting small rubber powered free flights and micro sized DIY designs in balsa and foam. |
The best thing people could do in most cases, is to put detailed info and specs in the general threads, with useful titles and searchable terms, such as "this brand xx component weighs this xxx amount". Google search works well. I immediately found the last post in this thread with a weight spec, through google. Wasn't even just here, but where he posted the same info elsewhere. Information in stickies such as "post decals here" tends to become a large collage that few would ever look through. Vendor lists become obsolete overnight, and don't seem to be maintained. Some of the fewer stickies that hold their value over time and make sense to be posted as a good central reference point (as google search also is a good central reference point) are ones such as the Guillow's sticky, with build thread links.
I am new in micro rc , i want advice in the most economical "cheap" receiver under 4 grams that I can bind with a MLP4DSM transmitter radio.
I want to build something like the TY model 3-2 from Banggood , see linek below. The electronic cam in a kit (radio, motor/reducer, propeller, micro actuator and lipo) $18.99 , see below link. I hope anybody can help. Thanks https://www.banggood.com/TY-Model-3-...ft-hotproducts https://www.banggood.com/TY-Model-3-...ft-hotproducts |
Reason: forgot to add detail of the electronic kit.
if the blade is a spectrum (seems to be on their site), then banggood sell this :
https://www.banggood.com/2_4G-4CH-Mi...p-1072251.html but be aware that it is dsmx only, not dsm2 protocol there's a review i wrote here : https://www.rcgroups.com/forums/show...c#post36260798 edit : this link http://www.ebay.com.au/itm/Blade-E-F...-/172381496700 suggests it is indeed a dsmx transmitter, so that receiver should work with it happily |
When i need an ESC?
Thanks for the clarification and the review is very informative. My Blade is the same as you have in the link , i will give it a try.
Few more questions 1.Since this is my fist rc plane, can you help to understand when do i need to have a ESD connected to the receiver? Is this for brushless motors only? 2.Should the servos be DSM too in order to work, or can use any servo? or what do i need to ensure if i want to use any servo with the receiver in our replay 3.I do not have a proper radio transmitter yet. With many protocols DSM, PPM....., is there any advice about what protocol or radio band should be a better option for indoor micro planes? I was thinking in a Devo 7e that can use several protocol but require some hacking work and maybe soldering, or in the other side just get a Spectrum and just stick to DMS protocols . I hope you can comment in this question or send me some link for other threads on this subject for micro planes Thanks Again |
Micro Component Weight Chart - PLEASE HELP BY CONTRIBUTING!Quote:
This thread is not the proper location for your questions, it is dedicated to information about various component weight, You should have opened a new thread instead. https://www.rcgroups.com/forums/newt...newthread&f=85 |
So. Just received the 3mm "Aero-modelling Foam Board" package from hobbyking.
20pcs of 1000x500mm measured 47mm high stacked and 970grams together. Thats 2.35mm, quite far from 3mm Weightwise i think i remember depron to be 135gr/m2 and this is 97, so thats nice. Compare to my only half sheet of depron it seems to be quite close in stiffness. No scientiffic measurement done yet. Not alot but this might be information that someone needs. /Ulf |
Thread Tools | |
Similar Threads | |||||
Discussion | Esky Lama V3/V4 component weight data | knutb | Coaxial Helicopters | 4 | Jan 05, 2009 10:58 PM |
watts/weight chart thingy | buffpants24 | Parkflyers | 3 | Apr 16, 2005 09:46 PM | |
Covering Weight Chart | genovia | Parkflyers | 14 | Oct 21, 2003 07:05 PM | |
Oracover/Ultracote weight chart here | Balin | Electric Plane Talk | 1 | Nov 26, 2002 12:06 AM | |
Cell/Pack weight... chart?? | JamesMadison10 | Parkflyers | 7 | Mar 12, 2002 11:24 PM |
