so now that we have a (or should have) a programmer, all we need is to develop some Firmware for altitude hold and elevator control
Crazy1 |
So from looking at "AL PAPPY" the movie, its incredible to get flight times like that. Maybe he would like to share his setup with us,..
The big question is does the Nova Cyclop 1.0 hold altitude,.. There is a connection with the elevator servo, or is that just for making a turn. |
Filed a support request with HiModel to get the firmware programmer. Suggest everyone else who bought from them to do the same. Here is a template:
Hi, I've bought NOVA OSD from you on DATE (order YOUR ORDER NUMBER). Since then several bugs have been discovered in NOVA OSD firmware and reported on RCGroups (see https://www.rcgroups.com/forums/show...547637&page=49). The manufacturer has acknowledged the defects and, as reported by BEVRC, is issuing firmware programmers to all affected customers. I, as many others who bought NOVA OSD from HiModel, want to get my NOVA OSD programmer to fix the firmware bugs. Would you please send the programmer (or instruct the manufacturer to do so) to YOUR ADDRESS Thank you. |
1) I have not seen any effect on the NOVA of calibrating it with different throws. It seems to me the calibration looks only for direction and not magnitude. 2) As of now there is no way. Recently there have been some reports of users being able to update firmware so it may be possible in future.... wait and see Gavin |
i did notice it kept its altitude nicely on rth with preset throttle.. well on calm wind condition anyway notice you're in perth mate, wer bout you fly? i'm in south of the river.. |
Looks like Foxtech will be on board to help with this issue guys !!!!
2012/3/14 Hey there Fu , Hope all is well mate. I have a question for you regarding the mah bug that the Nova osd has. It appears that bevrc is sending out a firmware flashing tool to all people that have bought one from them. Could you look into this for your purchasers as I bought 2 of these from you recently and have struck the mah battery use problem also. My orders where Order #5700 and Order #4777 Can you please look into it for us as its very important , I have lost one plane because of this already , and wont use again till its fixed. Patrick Coolahan -------Original Message------- From: xing fu Date: 15/03/2012 6:21:58 PM To: patrick Subject: Re: Nova osd bug fix dear sir we don't have that flash tools yet, if we have it ,we will also send it . cyclops confirmed there is a MAH error in the firmware thanks Fu Thanks for the reply Fu , glad to hear your on board to fix this issue for your customers. Please let us know when you have them to send out . Could you also mention to Cyclops about possibly including altitude holding in the firmware update, I know a lot of people on rcgroups have noticed that even thought the elevator is used in turns , it is not used to hold altitude properly. Thanks for you help Fu. Cheers Patrick Coolahan Australia |
[QUOTE=mkuvy;21038301]Filed a support request with HiModel to get the firmware programmer. Suggest everyone else who bought from them to do the same.
I just opened a support ticket with Himodel too. I named both BEVRC and Foxtech as being onboard, so hopefully the peer pressure will motivate them. I recently had an issue with an FPV monitor I purchased from them and their communication and support were very helpful. It was Wang that helped me. Anyone else who bought the Nova OSD from Himodel please open a ticket with them. |
Getting the firmware rewritten to include altitude hold would be awesome! Sam |
For sure with the right throttle setting the altitude won't change much but the Nova does not control altitude even though the gps altitude is good enough for coarse control. I'm south of the river too. Fly any open space I can find :-) and always looking for new spaces. Gavin |
Regards Doug |
ANOTHER VIDEO OF MY FLIGHT TEST ON THE NOVA OSD (RTH).
YOU CAN SEE THAT THE NOVA OSD 1.0V CAN HANDLE THE ALTITUDE VERY WELL
MY EQUIPMENT IS: SKYWALKER 910 MHZ AND 0.8 WATT OUTPUT VIDEO TX DRAGON LINK 2 BATTERY 11.1V 5000 MAH TOTAL 10000 MAH. 1 BATTERY 11.1V 1300 MAH FOR VIDEO NOVA OSD 1.0V RTH OPERATION STARTED AT 5012 METERS FROM " HOME" AND THE ALTITUDE WAS 555 METERS ON MINUTE 28:03 OF THE FLIGHT. AND YOU CAN SEE HOW CAPABLE IS THE NOVA OSD 1.0V TO HOLD THE ALTITUDE OR SO............ THIS IS ONLY AN APPRECIATION |
Then, I realize that english is not your native language (it's also not mine as one most likely can see). But please provide some proof why you think that the OSD controlls the altitude other than by just failsafing the throttle to a degree where the plane flies horizontal. Unfortunately the video you posted is not available - at least not at the time of this writeing - but I wonder how you want to use a video to proof that the altitude is not only kept by the sheer throttle / failsafe thing? Markus |
The NOVA can't keep the altitude. Maybe you was just lucky.
As an old user of FMA Co-Pilot system (that use the same logics) the main difference is the NOVA uses just 2 thermo coupler, the Co-Pilot - it can keep the altitute - 4. With four sensor pointing also forward and backward or mounted diagonally it can keep the altitude using the elevator. In the case of NOVA the elevator is connected only for elevon planes, you can easy test it at ground if you move the plane on it's roll axis with PA active the airelon (or rudder) moves, if you move the plane on it's pitch axis nothing happens. About the error of the current sensor I think maybe there is a fix by changing a resistor into the sensor board. I get some measure of the output of the IC and the error on mine it's about 0,03v if I can push in some way this 0,03v more to the OSD board I will fix the issue. Probably a resistor need to be changed. I'm waiting the help of a friends that know electronics better than me! Any suggestion? Roberto. |
Assuming the nova would correct altitude, that test wouldn't make it show. Altitude would have to rely on gps data, the IR sensor only works in one axis. Maybe run down a hill real fast with it and look at the elevator lol!
Thread Tools | |
Similar Threads | |||||
New Product | OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) | billpa | FPV Equipment | 11457 | Oct 29, 2018 11:10 PM |
Discussion | Cheap OSD with RTH? | raRaRa | FPV Talk | 4 | Sep 15, 2011 09:20 AM |
Discussion | What's a good RTH system to use with FOXTECH CE OSD? | ajusaf | FPV Talk | 13 | Jul 07, 2011 04:49 PM |
Question | Hexacopter with KKmulticopter, dragon OSD and RTH | evo585 | Multirotor Drone Talk | 0 | Mar 27, 2011 09:46 PM |
Discussion | Need help with Eagle Tree OSD RTH! | Ellis108 | FPV Talk | 2 | Nov 30, 2009 11:28 PM |
