Apr 22, 2017, 01:38 PM
totenkopf's Avatar
Gotha P60A1
Getting ready to do this Luft 46 plane in 1/8. Twin 90mm. Too cool
Apr 22, 2017, 08:06 PM
p901P901's Avatar
Finding out with these high sweeped wings you to land fast to prevent tip stall if there is not enough twist. I wonder how drag rudders will work to prevent tip stall?
Here is some information. Wish I new what airfoils, washout and if there was a gyro for the drag rudders.
gotha p60 rudder (0 min 33 sec)
Euroflugtag 2015 - Gotha P.60A (1 min 47 sec)
Good luck
Apr 22, 2017, 09:01 PM
totenkopf's Avatar
Gotha P60A1
Here is the book I am using. In depth on just the P60. I will get pics out tomorrow of the fuse plug, engine nacelle plug and wing. I have all the wing rib profiles for the wings. Was going to make the fuse and engine nacelle molds but got tired of making molds. Going old school and will make glass parts from the fuse and engine nacelle plugs. This is the kind of plane where you build it from the only known drawings. Face it the P60 in the video you showed, that guy built it from the same drawings I have.
Jul 30, 2019, 03:42 PM
Holy it's been a while! so probably too late now but the idea was to build with ribs. Do you still have that file?
-Daniel
Jul 30, 2019, 03:44 PM
Originally Posted by flyingman12
Are you building a build up wing or hot wire foam core?
I can send post the build up with ribs at 4". It does not have the wheel well mounts or servo mounts.
-Daniel
Jul 30, 2019, 08:45 PM
p901P901's Avatar
-Daniel
Yes I still have the file.
Discussion Me-P.1112 (a Luft46 project) heiner Scratchbuilt EDFs 5 Sep 09, 2011 09:33 PM
New Product New 20mm EPP WWII Series, ME-109 and P-51 2dogrc Electric Warbirds 0 Jun 08, 2011 12:36 PM
Sold Gws p-51 mustang and me-109 pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 8 Apr 13, 2011 04:02 PM
Wanted CF UM Project: Sell me your UM Sukhoi and P-51 airframes, wings, etc! S.R.G. Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 06, 2011 10:33 AM
Help! FS: Miniblade, ME-109, P-51, P-40 (ie sucks to be me) McGrrr Aircraft - Sailplanes (FS/W) 21 Jun 19, 2005 04:34 PM
