Various shots taken by my buddy Gerard.
I have flown the Tigra quite a bit and I really like it.
In addition to flying on really light lift, and looking cool in fly bys, it is a blast for doing sequential loops, my record is 5 in a row. It also does an OK wing-over. I need to try rolls with aileron differential turned off. It really doesn't stall. Installed at very high angles of attack at low speed you lose lateral control and it whips around turning downwind. The key is to push the nose down before it gets to that point. Definitely a keeper. |
Here's a question for you guys who have been flying the Tigra for a while.
I've been flying my Tigra for a couple of weeks now and I'm a bit stumped. It flies very well in a wide band of wind speeds, but it has an annoying trait of pitching up and climbing with speed. At the moment, the CG is such that the elevons are level with the TE in level flight. (right at 107) I've tried moving the CG forward and back, and I've given up and decided that maybe this is how this airfoil flies. Also, rolls are not axial at all and I think that is also an attribute of the airfoil. It flies around nicely in light lift and thermals very well, but in a dive or fast pass, or when the wind picks up, I have to really push the nose down. Inverted flight requires a lot of push. It flies fine, just not like my other planes. Has this been your experience or have I not got it balanced properly yet? I must admit, I DS'ed it yesterday in 3-4 mph and it was smooth but it took a bit of practice to get it to not keep cutting in after the bottom turn. |
Hello Bluzharp,
I would say your experience is similar to mine. It does tend to pitch up with increase in speed/lift and you need to push the nose down to keep it from pulling up and weather-vaning. In general as lift/speed pick up I add down elevator, typically flying with 1-3mm down. I only fly with the ailerons level with the TE under the lightest of conditions. As the speed/lift picks up I dial in more down. I have my radio programmed with three different sets of down trim. I agree rolls are not axial, especially if you are flying with the recommended differential. I have only flown a few planks, but I think all this behavior is typical. It did take me a while to figure it out too. As you said, it flies a little different, but is a lot of fun, especially under light conditions. The plank wing construction is also very strong. I feel comfortable tossing it out under any condition. Even if it results in a poor landing/crash, there is no damage. In addition to flying under a variety of conditions (if you stay on the trim) it does multiple sequential loops really well. My current record is 7. Enjoy Greg |
Thanks Greg. It's good to have confirmation. It's a fun flyer for what it does. I have a number of planks/wings and they are not like this. They can be balanced for neutral inverted flight and can be wound up to very high speeds with no attitude change. Rolls are dead on center like screw threads.
As you made the the point, the Tigra is a bit different and performs the function it was designed for very well. When I try to push it into another area, some adjustment is required. I also agree with your point that it is surprisingly rugged. Our local LZ here is somewhat sketchy and I don't make it to the weeds every time. So far there has been no damage from a couple of stony landings. I did put a bit of Scotch 471 clear vinyl tape on the nose and underbelly section for protection. I should have painted the bottom a bit more for visibilty, as this baby will thermal out of sight in a hurry! |
It does sound like our experiences of the Tigra match.
The only other plank I have is a Fauvel: https://www.rcgroups.com/forums/show...1465565&page=5. It took a while to sort out, but it is a blast. It also rolls quite axially, but has an elevator in addition to ailerons. Greg |
I continue to fly the Tigra regularly under light conditions and really enjoy it!
Its ruggedness is also quite impressive! I have cartwheeled it more than once! |
Yes, I agree that finding the CG is critical.
I also fly with three different preset pitch trims which I change depending on speed and lift. From what I can tell, this is typical for planks. It does especially nice hammerheads and barrel rolls! And of course it loops tightly and infinitely! Greg |
Tigra RIP - Not!
I was flying the Tigra today under light conditions while a good friend was flying his $$$$ 3m moldie close to the slope.
In the tight airspace we we collided! The Tigra wrapped itself around his V-Tail and the pair went into a flat spin landing horizontally between rocks with no damage to his plane! I said "phew"! He bought me a couple beers, so we are good! I have a new wing on order! |
Interesting idea bluzharp. But I am uncertain it would fix the problem. My other plank, a Fauvel, flies identically. |
Thread Tools | |
Similar Threads | |||||
Anyone try the Art Hobby Ibis 3M? | GBR2 | Thermal Soaring | 4 | May 14, 2005 11:05 AM | |
anyone flying a hyper from art hobby? | snowfallonme | DLG Hand Launch Gliders & F3K | 7 | Jan 27, 2005 08:06 PM | |
Art Hobby Timon 2m Anyone?? | tomi | Thermal Soaring | 8 | Jul 16, 2004 01:30 PM | |
Anyone own a Colibri by Art Hobby? | Looooeeee! | Electric Sailplanes | 11 | May 14, 2001 09:54 AM | |
Has anyone built a Sierra from art hobby??? | ORANATOR | Electric Sailplanes | 2 | May 09, 2001 01:15 PM |
