Jan 16, 2016, 08:38 AM
above us only sky
Renfield's Avatar
Hi Drra. Welcome to RC Groups and the Icon A5!
I don't know where you are, but this model of the Icon (not guanli) is still available through Hobbyking. https://www.hobbyking.com/hobbyking/s...arehouse_.html
It has been very well sorted out in this thread, and you should find all you need to know right here by search or by a read through.
Good luck!
Jan 17, 2016, 05:17 PM
Electric Coolhunter
Thomas B's Avatar
Good luck!
Apparently at the Russian warehouse, only.......
Latest blog entry: RC events for 2019!
Jan 17, 2016, 05:20 PM
Electric Coolhunter
Thomas B's Avatar
Originally Posted by Drra View Post
I just found this.
Anybody has done this modification? would be grate to see more in deep info about it
I simply twisted in a bit of washout by hand. Greatly reduced the tendency to drop a wing in slow flight and turns.
Worth making sure than any sharp leading edge mold line is removed from the wing. This sharp mold line induces stall/airflow separation sooner than a smooth leading edge.
Jan 18, 2016, 08:56 AM
above us only sky
Renfield's Avatar
I didn't say it was readily available at a hobby shop near you. Only that it is available.
OP might well live in Moscow.
Getting rid of the mold line on the leading edge has worked very well with the PZ Icon. I wrap that edge with packing tape. Helps with dings too.
Nov 07, 2018, 01:39 PM
rckamikaze's Avatar
1090mm Icon
I seem to be a few years late to the party,.. I just put one together from replacement parts. I have no manual, Can anyone provide control surface movements,???
All I've found in the posts is "all you can get".
Thanx
"out of power, altitude & ideas"
Nov 07, 2018, 10:38 PM
RC Aircraft Junkie
jlk69's Avatar
I wouldn't worry too much about control surface deflection amount. Just setup dual rates of 100% and 75% on all surfaces and use 75% for first flight. The main issue I found was not enough power with the stock motor to take off from water. I had to put a more powerful motor to get the plane to get up on 'step' . With the stock motor more often than not the nose of the plane would start to duck down into the water.
New Product GuanLi Icon A5 flyandi Electric Plane Talk 398 Sep 24, 2014 12:53 PM
Discussion 'My' Guanli Icon A5 FINALLY flies.... hfsarber Waterplanes 0 Sep 25, 2011 05:32 PM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion HobbyKing Icon-A5 for FPV? djdavid60 FPV Talk 7 Jul 13, 2011 03:20 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 11:40 AM
