Nov 18, 2011, 01:11 AM
Tezact
tezact's Avatar
hi Start latex rubber tubing
Hi everyone,
I have had enormous trouble finding sensibly priced latex tubing for a new hi start or bungee launch setup. I was about to buy from the US when I read an item regarding the pros and cons of the two widely used products in the US Namely Aerofoam's Monsterhose and Theraband. It seems the two are very similar in quality (both using tubular latex rubber).
After a little Googling I found that Theraband is available in 30m boxed lengths from an Aus supplier.
The product is colour graded to reflect stretch/strength.
The red, green and blue appear to be suitable for up to 3m sailplanes whilethe silver and black are for larger ones.
The supplier is online at www.sportstek.net and then do a search of their site for Theraband Tubing.
Cheers
Tezact
Nov 18, 2011, 01:30 AM
Not enough hours in the day
Slaanesh's Avatar
Hobbyking has some
You can double it up if it's not thick enough.
Nov 18, 2011, 01:40 AM
R2hobbies have complete ready made hi-start/bungee launch systems
reel and parachute included for very good prices!
http://www.r2hobbies.com/eng/proddet...od=rcps3926013
http://www.r2hobbies.com/eng/proddet...od=rcps3926014
http://www.r2hobbies.com/eng/proddet...prod=rcps71902
Az
Nov 18, 2011, 02:04 AM
Member #1
Teamsherman's Avatar
I once bought a reel, bungy, parachute and stakes from kelletts for about $50 a few years back do you should be able to find one on the cheap.
Nov 18, 2011, 03:17 AM
KE your cub.
Curare's Avatar
buy one? get your other half to make one!
Orrr if you're really lazy just tie a bit of ribbon to it so you can find the end.
Nov 19, 2011, 01:43 AM
Is my CG correct?
discostu956's Avatar
Was going to mention the hobbyking tubing. Cheap as chips
Apr 02, 2019, 06:36 PM
ErcoupeEd's Avatar
I usually buy my latex tubing from a medical supply house supplier.
Usually the lowest cost alternative.
Question how to secure hi-start tubing? planepainter Thermal 20 Oct 12, 2011 06:37 AM
Wanted hi-start bungee tubing planepainter Aircraft - Sailplanes (FS/W) 3 Oct 04, 2011 09:50 AM
Wanted Hi Start or rubber tubing will_newton Aircraft - Sailplanes (FS/W) 11 Mar 19, 2006 08:56 AM
Hi Start Rubber Tubing on E-bay Matt D. Aircraft - Sailplanes (FS/W) 0 Mar 10, 2005 11:12 PM
FS - Heavy duty hi-start rubber tubing glider34 Aircraft - Sailplanes (FS/W) 4 Mar 25, 2004 11:19 PM
