BabbelBatts - Page 19 - RC Groups
This thread is privately moderated by RCBABBEL, who may elect to delete unwanted replies.
Sep 04, 2017, 12:40 PM
**I'm Battman**
RCBABBEL's Avatar
Originally Posted by Flash22
RCBABBEL,
I just purchased a umx Timber from Horizonhobby. I need your recommendation on a battery charging cable and what is the best batteries to use? You were recommended in rcgroups, you had the best batteries to use in the Timber. If you could let me know how much the cost would be and how to buy these items from you that would be awesome. My email address is jr854@cox.net.
I would really appreciate it very much so. I am fairly new to rc aircraft.
JR Butler
JR B,
PMs & email sent.
Happy Labor Day!
The flying was fabulous this AM!!
Roger
Sep 04, 2017, 08:15 PM
LUFTGUCKER
lotsasteam's Avatar
Need battery charging cable for the UMX Timber,Could you recommend a good midsize battery,please,Thank you! (Need order info)
Sep 04, 2017, 08:56 PM
**I'm Battman**
RCBABBEL's Avatar
Do you use a hobby grade charger with banana jacks?
If so, go with this charge harness:
Six-port (2S) parallel JST-PH charge & balance harness.
$8.95
It can charge from 1 to 6 (2S) UMX batts at a time.
https://static.rcgroups.net/forums/a...pter%20003.jpg
Midsize batt for the UMX Timber?
I would start with this:
BB Hyp (2S) 330mAh RTF 50C max w/UMX connector.
$14.95
Shoot me a PM anytime to order:
https://www.rcgroups.com/forums/priv...=newpm&u=54990
Roger
Sep 06, 2017, 11:48 PM
jamesppp's Avatar
I got mine tonight . I did the tiny bit of setup the manual calls for but haven't bound it to thr dx9 because I let the battery get a little more discharged than I like and it is almost 1 am
Do you not have to do any TX programming for the flaps.
Looking forward to flying tomorrow
Sep 12, 2017, 07:28 PM
markhoho's Avatar
I finally got a chance to run Rogers 330mah 2s batteries that I just bought thru my planes wow why did I wait so long to buy them. The most impressive was when I put it into my non safe umx Habu the change in its vertical performance was dramatic. It may not be be unlimited vertical but it got small fast and let's it do huge powered loops. Thanks Roger you da man.
Sep 12, 2017, 07:34 PM
Curious if any of you have recommendations for storage and transport of these little 2s and 3s batteries? I usually just carry them loosely, but my OCD makes me think they should be better taken care of.
Sep 14, 2017, 01:35 PM
Originally Posted by RCBABBEL
JR B,
PMs & email sent.
Happy Labor Day!
Roger
Roger,
I received my order. Thank youfor the fast service.
I really appreciate all your help.
JR
Sep 29, 2017, 01:01 PM
**I'm Battman**
RCBABBEL's Avatar
Flying (2S) UMX planes on (3S) BabbelBatts:
I've been flying 3S batts in my UMX planes for over 6 years.
Love it!!!
Static motor testing should be done with short bursts only.
Long static motor run times will almost always trigger OCP.
Test 3S batts in flight.
Take-off at half throttle until you get some altitude.
If OCP (over current protection) kicks in, just lower the throttle stick to idle for 1 sec and throttle back up.
Additional air-flow over the brick helps greatly!
Balance the prop & spinner assembly.
Flying in cool temps makes a big difference.
Use throttle management.
If OCP is a problem, install a lower Kv motor and/or prop down.
Roger
ps...Twin 3000Kv motors on 3S power.
I'm very excited to fly the new UMX Aero Commander!!!
https://www.rcgroups.com/forums/show...Aero-Commander
Oct 11, 2017, 05:47 PM
Blade 130X heli battery ???
Hey Roger, do you have a equivalent battery for this Blade Helie that would work ?
Oct 11, 2017, 08:30 PM
**I'm Battman**
RCBABBEL's Avatar
ks,
Do any of these stock dimensions look like they would work?
HYPERION G5 3S 320MAH 50CMAX
50 x 25 x 5mm
or
HYPERION G5 3S 450MAH 50CMAX
55.8 x 30 x 14.8mm
Roger
Oct 25, 2017, 11:55 PM
GBX
GBX
Roger with the Aero Commander just starting to Ship
Let Us Know the Best Babbel Bat for it
Nov 01, 2017, 08:31 PM
Elfi Flyer
Doug Sipprell's Avatar
Ditto! And, it's great to be back on RCG.
RD
Nov 02, 2017, 07:28 PM
**I'm Battman**
RCBABBEL's Avatar
I think this will be the best AC batt.
I will know very soon.
*New
BB Hyp G7 (2S) 600 HV 75C max w/JST conn. (Si-Graphene)
$21.95
Approx: 30g
I just upgraded the wire size to 18 AWG.
Should be an excellent combination of power vs weight in the AC.
RD
RD,
Welcome back!
RCG is a great place to be.
Roger
Nov 02, 2017, 08:41 PM
pull up -- PULL UP!!!
75C, interesting. CxAH = 45amps, hooked up thru an officially 3A connector. I think they come with an XT30?
A caution -- most battery companies list the steady state C followed by a burst C. Hyperion does it the opposite way. Other companies would call it a 30C battery.
Nov 02, 2017, 09:30 PM
**I'm Battman**
RCBABBEL's Avatar
Yes.
Stock conn. XT30
From Hyperion:
Discharge Rate: 75Cmax (75C burst, 30~40C continuous)
Charge Rate: 6C maximum, 5C recommended.
Roger
Sold Sukhoi SU-26XP and 6 Hyperion 180 BabbelBatts turnerm Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Aug 22, 2011 09:45 AM
