Depends on construction techniques IMO. If you guys are going with hollow molded parts & skin hinges then is best to avoid the rounded off wingtip. If your using conventional dubro, hayes (my favorites for speed models) or ez hinges, then its imo easier to just cut off the entire elevator including the tip prior to cutting the hinge slots.
Latest blog entry: original Y/A F-18 Kit
i think a nice hinged in the mold elev (Kevlar) would be sweet i like #4 also it just looks right . i've been testing a core material that would make a nice stiff composite skin.it's very lite and not as expensive as some core materials.having a sandwich of glass/core/glass is the way to go.
whether the servo is inside the fuse or outside the fuse, wouldn't the servo horn and linkage line in the same spot on the elevator? Unless you moved it way out on the stab of course but it would get real thin and be no room for the servo. With the servo mounted inside the fuse you can rotate the servo to get the linkage 90 degrees with the hinge line which is always best. I set up my Blaze like the Bandit with the linkage parallel to the flight path to reduce drag, but if servo is mounted inside the fuse, drag won't even be a concern.
It's 14.5lbs with 10lbs installed thrust....its only going to go so fast
Yeah the horn and the servo movement should all be in line yeah. I though guys were saying the servo had to be rotated so that the linkage was 90 degrees to hinge line, which is not true based on the fact the Bandit elevator and rudder are not 90 and either is the Electra's elevator, rudder, or ailerons. Its not a 3d plane where we need 3" deflection. |
Well swept elevators with servos inboard under the thrust tube and rods slightly skewed out arent going to cut it much for mechanical geometry.
And there are other dealers around the world also looking into this so how about we stop jumping on anyone who says something that doesnt toe the line for our "favourite" shop, HET will take all the info onboard and then build a new Stab and we will all be happy |
Latest blog entry: Extreme RC AUSTRALIA
Robert, for ease of implementation and testing purposes options 1 and 2 would be my pick. The only deviations I would do is to carry the elevator all the way out to the tip (i.e. remove the ends as suggested by Extreme). I would also narrow the elevator cord/width. With this setup a single servo (GOOD) is still an option.
I was curious how the mod would look so I did a quick Paint mod Fly this and make adjustments as needed. |
Reason: spelling :)
Removing the tips makes it look like the wing, makes is easy for the factory to use the current Stab (albeit with mods, like a nice big Trailing edge twice the width of current one and using hard stock balsa) And means the elevator will move at 90 deg to the servo.
You could have a one piece elevator and still have 2 servos if you wanted to, my drawing was not to scale and still isnt but here is another version with the blue outlines showing where the hard balsa LE & TE should be, and the hardwood spars in the Stab just for clarity. Oh and of course the elevator could be solid right across the centre, same width right through, as the exhaust overhangs the elevator anyway. |
With a split elevator there may be another problem created in solving the current problem.The horns would have to attach to the inside edge of each elevator half.
The best position would not be at the edge as it would put a twisting force on each elevator. If not at the edge, then the pushrods would have to go through the side of the tail cone, if the servos are mounted inside, as in the diagrams. The split elevators may work better, even look better , but then the whole tail might have to be re-designed. The tail part of the fuse is thin, unsupported, and subject to twisting. You actually have to inspect a current model of this plane in order to visualize how a fix could be made. End result without a major change to the design would be a better one piece elevator and solid stab. The present stab is hollow and actually crinkles if the bolts are tightened. CN and Ace don't have a flutter or weakness problem, so perhaps the fix is simple, solid stab, single one piece elevator, better method of attachment. |
Vic, how old are you? Seems to me the force is not strong in you. You must yield to those jedi who know much more before you.
+100 to Mike master Jedi. |
Thread Tools | |
Similar Threads | |||||
Cool | New HET L-39 90mm by EJF.com | AceMigKiller | Electric Ducted Fan Jet Talk | 715 | Feb 28, 2018 08:28 PM |
Sold | Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. | airmcn_3 | Aircraft - Electric - Jets (FS/W) | 9 | Nov 14, 2011 12:37 PM |
Found | HET Sniper 90mm, airframe and maybe servos | Knife Liddle | Aircraft - Electric - Jets (FS/W) | 2 | Oct 01, 2011 11:10 AM |
Sold | NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor | mcgoughman | Aircraft - Electric - Jets (FS/W) | 0 | Aug 30, 2011 08:35 PM |
Sold | HET All Composite Super Sniper | priscalex | Aircraft - Electric - Jets (FS/W) | 0 | Jun 30, 2008 09:17 PM |
