Some of the 'better' FC systems use dedicated ECSs that are controlled via an I2C interface which is a 2-way data flow. Mikrokopter for one, but the Conrad (Reely) quad I started with had this too. Plenty of advantages for example you can put a finger into one of the props on the Conrad and all 4 motors stop instantly (great safety feature). With the MK, stuff data like ESC temp is passed back to the FC and can be viewed via telemetry. It also monitors motor condition and will report a drop in power. I assume it does this using voltage/current/rpm feedback from the individual ESCs - sensored motors are not required.
This is the Conrad ... you can see the I2C ribbon cables running from the FC board in the centre to the ESC boards each side. Each board runs two motors. |
Latest blog entry: Eachine QX65 FPV quad review
[PROG.MIX5] <OFF> or <ON> depending on position of switch H (OFST arrow GEAR) RATE 54 MIX>OFF MAS>OFST SLV>5:GEAR LINK>OFF SW>H POSI>DOWN I believe I could have used any mix but just chose 5. I think perhaps I adjusted the rate to get the slider to fall in a FAILSAFE box on the ASSISTANT. RX Channel 5 is the channel I chose for the flight modes GPS A M and plugs into U I believe on the MC. |
i have a question regarding the frequency of the esc. Naza manual says 400hz. It is up to 400hz or need specific 400hz esc frequency. What will happen if put esc at 500hz with the naza.?
Secondly i project to buy thoses : https://www.hobbyking.com/hobbycity/s...ontroller.html or thoses : http://www.rctimer.com/index.php?gOo...0&productname= Can anyone know if thoses are plug n play compatible with the naza (in 400hz native). The frequency refresh output is not mentionned. I dont want to flash anything, just esc that performing well (that's why i'm interested with the simonk already flashed). |
What frame is that you were using ? Looks super lightweight.
That's the Conrad frame - yes, it's very light. This is what it looks like as standard, with folding arms
I'm still using the centre spaceframe with the Naza but with a new arm set on top I've got two extra motors and ESCs so will be moving everything to an F550 at some point though. The Conrad frame was all set up with the landing gear and gimbal so it was a quick conversion. |
This is not Naza controlled but is very cool.
You mean the whole video is fake, crap, I just sent $5,000 to a guy in Nigeria to buy one. Lol
I am not sure if this is the right thread to ask but i ll give it a try. I was running my Naza on an HK f450 clone with 10" and 8" props. It was running very smooth. My 10x3.8 SF APC props had to be replaced so i thought of trying some APC 11x5.5 electric props for more lifting. I received them checked that they are balanced and put them on. But i get a very bizarre behavior. It flies very smooth for a couple of seconds and then i get a hard glitch as if i am very high on the gain. I mean very high like 5 times the value I should be on. I faced many times false gain values and this never happened to me. Gain is at 150% which is the same value as 10" props and the 8". Any ideas what i might be experiencing? I ll try again tomorrow with the 10" see if i have this behavior again.
Thread Tools | |
Similar Threads | |||||
New Product | DJI WooKong-M Autopilot System for multirotors **Owners Thread** | DJI INNOVATIONS | Multirotor Drone Electronics | 20306 | Nov 26, 2017 09:01 PM |
New Product | MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC | JussiH | Multirotor Drone Talk | 707 | Jan 01, 2013 09:54 AM |
Discussion | DJI Innovation helicopter autopilot XP.3.1 for European customers | JoelT | Aerial Photography | 2 | Sep 24, 2009 11:43 AM |
New Product | United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. | JawaSnack | Hot Online Deals | 9 | Jul 17, 2007 10:31 AM |
Futaba FC-18 teacher to FC-16 pupil problem . | jmquetin | Radios | 5 | Nov 02, 2004 07:48 AM |
