Jan 18, 2013, 01:16 AM
BerndM's Avatar
Originally Posted by foamwingnut
Hey guys,
I've got a 450 that is stock across the board. I've been flying it with a 3 cell 2200 which I will probably bump up for more flight time. Can anyone tell me what the safe payload capacity is? How can I tweak my set up to get the most out of it?
Thanks!
Check out my Signature info and you'll see what I use.
I get anywhere from 10 to 15 minutes of flight time depending how aggressive I fly.
Regards
Bernd
Witespy-DJI NAZA F450 Flamewheel
2212/920kv DJI motors and Opto 30A ESC's
10x4 Gemfan Woodies or 10x5 Graupner E props
GoPro Hero HD2
Fat Shark Predator V2 FPV
AUW with Turnigy 3S-4000mah = 1585g
Spektrum TX DX-7 (original) / Spektrum RX AR6200
Jan 18, 2013, 03:32 AM
INAV
Olivier_C's Avatar
My F450 (stock motors+ESC, 9" Graupner props, 4S 2800mAh) weights 1080g with no payload, 1290g with GoPro+housing, and I've just added 210g of FVP gear and it didn't make any noticable difference in flight (and I like it alive) or LiPo life (I get 11-13 mins).
I think it could carry 300g more for a total of 1800 without much troubles.
For a 3S, 1500-1700g seems quite fair, wild guess.
About the Naza flying level (or not ), I have a video, was zooming around, not using the throttle that much, some time you can see it's loosing some altitude when the turns are too hard, but most of the time it's quite decent I think... 1st few seconds in the video, its : take-off to 2 meters high, full forward for like 6 secs, release, hard yaw for a 180°, then the quad is about 1 meter higher, from the turn.
I suspect it may all be about the shape of the machine, mine is quite "streamlined", there's no stuff hanging below, I don't want it to look like a flying radio tower. No offence to radio towers ! =)
Quadcopter - 04/01/2013 (1 min 27 sec)
Jan 18, 2013, 04:26 AM
Originally Posted by alwaysconfused
I am going to try the G10 first. If the prices are right I might just stick with it.
having just made by big quad and gimbal from G10 (easily available from a local PCB manufacturer), you had better stock up on scroll saw/ hacksaw blades, and drills etc...... G10 and carbon plate are very abrasive to work with..... Carbon fibre dust is conductive too so keep it well away from any electronics.
Jan 18, 2013, 07:25 AM
Bill Glover's Avatar
Originally Posted by MCrites
Having flowing in working chemical plants, I agree to a point. These things are made to take the open seas and I cannot think of any way they could hurt the ship. It's all steel, the windows are made to take hurricane force winds... even if it happened to go into the exhaust it's so small in comparison it wouldn't even slow the exhaust gasses.
There's certainly equipment on a ship that you wouldn't want to crash a multicopter into - radar/comms arrays etc. But probably health & safety would be more of a concern i.e. flying near people. I work for a large shipping company btw, although not at sea.
Latest blog entry: Eachine QX65 FPV quad review
Jan 18, 2013, 07:27 AM
Originally Posted by Av8Chuck
What's your definition of a hobby grade coper?
One that's not operated professionally i.e. with the permits / insurance / certification / etc. that most countries require now for anything other than recreational flying.
Jan 18, 2013, 10:21 AM
Flying R/C since 1964
kallend's Avatar
Hey guys,
Thanks!
have you tried this?
http://www.ecalc.ch/xcoptercalc_e.htm?ecalc
Jan 18, 2013, 10:24 AM
What thickness are you working with? It looks like the dji parts are using 1.5mm. I dont have my slide measure but the ruler says 1.5. Now... I have a head cold and eyes are a tad runny from the sneezing but...lol
Jan 18, 2013, 11:58 AM
KG7TTQ - Hauser, ID
mark_q's Avatar
I use a carborundum cut off wheel (the really thin brown ones for steel) and it cuts through G10 and CF sheet like butter (I got tired of buying scroll saw blades). Of course there are still some shapes I need the scroll saw but not many.
You are right about the dust! I wear a painters mask if I am doing a simple trim and a full mask if I am doing complex cutting. Also true about the conductivity - KEEP THIS DUST OUT OF YOUR ELECTRONICS! (unless you like light shows and smoke).
Jan 18, 2013, 01:15 PM
Does anyone here happen to know if Banana Hobby offers their employees a vision plan for their insurance?
VID00443 (0 min 47 sec)
Jan 18, 2013, 01:24 PM
Empire Support
T J Gilbert's Avatar
GW's Luck
Goldsworthy, you and I have about the same amount of good luck... ZERO!
When you and your wife go on that cruise, I want you to visit the craps table in the casino.
When it comes time for you to roll the dice, bet with the house.
You should make a fortune...
Jan 18, 2013, 01:53 PM
Just spent the last hour with hellscream..lol I had the FPV set up running on it and it was balanced and working great (except the GPS) I need to figure out why the GPS plug wants to come out. oh..the gps on the osd .
This F550 is freaking AWESOME!
And I figured out why it is so wonky at the building. A: HIGH magnetic fields B: HIGH radio wave saturation C: The winds that cut through where I was trying it out are insane and come from many directions at once.
So..
No flying in that building..lol
Jan 18, 2013, 05:51 PM
I have my F450 with naza gps flying nice. Now I'm adding a gopro and iris aerial legs and bat wings.I'll be moving my batteries to the back batwing to counteract the gopro. I know i have recheck the balance and setup in assistant. But what if i use different size packs say from 2800 to 4800 will it compensate for that ?
Jan 18, 2013, 05:58 PM
Mine does. I was using a 5000mah. used it up, switched to a 2800 and it flew just as well. So unless it is a different cell number I dont think it would matter much in your configuration.
Jan 18, 2013, 06:48 PM
Empire Support
Different Batteries
Different size (mAh) batteries with the same cell count (3S for example) can be used provided the battery sits at or near COG.
If your battery is hung out away from the COG, changing from a 5000mAh to a 2800mAh will change the COG.
Changing the COG will make the airframe drift or not be flyable at all.
Jan 18, 2013, 08:09 PM
Weres you battery located?
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Drone Electronics 20306 Nov 26, 2017 09:01 PM
New Product MultiWiiCopter "MiniWii" FC - Cheap, small 6DOF FC JussiH Multirotor Drone Talk 707 Jan 01, 2013 09:54 AM
Discussion DJI Innovation helicopter autopilot XP.3.1 for European customers JoelT Aerial Photography 2 Sep 24, 2009 11:43 AM
New Product United Hobbies FC 28-05 & FC 28-22 brushless outrunners $5.95 ea. JawaSnack Hot Online Deals 9 Jul 17, 2007 10:31 AM
Futaba FC-18 teacher to FC-16 pupil problem . jmquetin Radios 5 Nov 02, 2004 07:48 AM
