Servos that won't centre - RC Groups
Nov 06, 2011, 01:53 AM
Great Southern Land
Berkie's Avatar
Hi all
I have 2 aileron servos that although centred properly with a servo tester, go off centre as soon as I connect them to the Rx. This of course reduces throw in one direction.
Does anyone know the answer to this?
Kev
Nov 06, 2011, 02:04 AM
DJ_
DJ_
Does it happen if you test it in different Rx ports, ele, alr, rud?
Nov 06, 2011, 02:39 AM
Which transmitter? Any mixers, sub trims etc. active?
Nov 06, 2011, 02:53 AM
Great Southern Land
Berkie's Avatar
Dang me!
Just went to do the test you suggested DJ, but now they are working OK
Got no idea what was causing it. Thought at first I had the wrong model selected in the Tx, but no it wasn't that.
Anyhow thanks for your help
Kev
Nov 06, 2011, 02:56 AM
Great Southern Land
Berkie's Avatar
No Jkettu, there were no mixes or sub trims set for the ailerons
Thanks anyhow.
Kev
Nov 06, 2011, 08:32 AM
Jack
jackerbes's Avatar
If you have any aileron trim set in on the TX, the ailerons will not stay centered, they will go to the trimmed state.
Same with any mixing settings that might set the aileron channels to anything other than the default state.
If the ailerons are on two channels (instead of one channel with a "Y" cable as is normally required if you are using flaperons ormixing features) that can give you more settings you have to look at on the TX.
And sometimes changing the model select to an unused channel that is set to defaults will let you tell that is one of the settings on the named model channel that needs to be changed to get it sorted out.
Jack
Nov 06, 2011, 11:18 PM
DJ_
DJ_
Berkie, glad its working now, but worried why it happened in the first place. Any chance they were plugged into Rx backwards, I'm grasping at straws but I hate when things "fix" themselves. Cuz they might come back!!
Nov 07, 2011, 04:36 AM
Great Southern Land
Berkie's Avatar
Jack
Thanks Jack. I have had a good look through the settings on the DX7, but the only thing was the amount of throw which was about 75% left & 85% right in an attempt to correct the problem. However I can't adjust the right anymore as moving the stick does not move the selector like it should.
Kev
Nov 07, 2011, 08:38 PM
Kev, is your flap switch in the center postion? If you are not using flaps, you can zero out all the flap settings and not worry about the switch.
Steve
Nov 08, 2011, 05:22 AM
Great Southern Land
Berkie's Avatar
Steve
All working now Steve. Thanks anyhow
Kev
Help! Motor keeps beeping and won't rotate while my servos are fine. kayjm10 Power Systems 21 Mar 04, 2017 01:20 PM
Help! Servos turn but motor won't haston Electric Plane Talk 13 Oct 10, 2011 08:40 PM
Discussion DSM2 6ch OrangeRX won't bind--won't even flash the LED horseflesh Radios 12 Jun 09, 2011 12:06 AM
Discussion SB/XC Flap Servos won't hold - suggestions? dbeach Cross Country Soaring 3 Apr 27, 2011 03:13 PM
Help! While setting up my T-rex, servos won't move the same up and down avt Mini Helis 2 Sep 01, 2007 10:21 AM
