Feb 12, 2012, 06:45 AM
therealthing691's Avatar
congrats Dr kazu much better improvement of maneuverability and great control with lots of power regards Brian
Feb 12, 2012, 11:13 AM
There's magic in those wings !
khaled_abobakr's Avatar
Originally Posted by Kazu-kaku
Flaptter19-7 of LAPUTA Flight in Snow&Wind
I change the size of Rear wings small for improvement of maneuverability of Flight.
Good Powerfull Flight.
http://www.youtube.com/watch?v=i1eYtaUBrhw
Good job Dr Kakuta
You are so persistent .... it flies a lot better now ...
Have you ever thought of using this quad spar flapping mechanism to make an Actively twisted wing ornithopter with multi layer EPP wing ??
I'm sure you will succeed in making it
Khaled
Mar 05, 2012, 09:53 PM
K Kakuta
Kazu-kaku's Avatar
New Flight.
Almostly, Flight is OK.
フラップター:Flaptter19-7 of LAPUTA Flight on Snow Ground (2 min 1 sec)
Now, I am maiking Dragonfly with 4 wings.
Mar 05, 2012, 10:46 PM
DIY Mania from Taiwan
Kakuta-Sensei:
your project Faptter In LAPUTA is very well accomplished,looking forward to your next project
my respect again.
thanks for sharing
best regards
Sam
Mar 06, 2012, 08:48 PM
I cant what to see your Dragonfly another masterpiece from the japanese master Dr Kazu regards Brian thankyou as always for being such a generous man and sharing and giving others inspiration to build
May 06, 2012, 07:09 AM
K Kakuta
Kazu-kaku's Avatar
Flaptter 19-7 of LAPUTA
Good Stable Flight.
フラップター:Flaptter19-7 of LAPUTA Good Stable Flight (2 min 17 sec)
May 06, 2012, 08:41 AM
thats flys great you must be happy with its flight
May 06, 2012, 02:16 PM
Doctor, your Flapter flies better and better.
Because of it I watched the original cartoon movie and find that it flies in the same manner.
Congratulations, seems you are able to make any dream come true
May 06, 2012, 05:14 PM
K Kakuta
Kazu-kaku's Avatar
Thank you.
Aug 12, 2012, 11:18 PM
K Kakuta
Kazu-kaku's Avatar
New Flight
New Flight
I changed ESC 10A to 12A.
フラップター:Flaptter19-7 of LAPUTA Very Good Flight (3 min 41 sec)
Aug 12, 2012, 11:59 PM
Good control and stability.
How much power does it use?
George
Aug 13, 2012, 12:12 AM
Definitely a great flying machine
thansk for sharing
best regards
Sam
Aug 13, 2012, 02:48 AM
K Kakuta
Kazu-kaku's Avatar
George
Flaptter 19-7
Width 80cm
Length 24cm
Weight 258g (Young Dola 6g)
battery Lipo 3cell 450mAh45g
Total flight weight 258g
Receiver:Corona 4Ch Single Conv. Rx 72MHz
cryistal: Castle Creations Micro Crystal Berg (72MHz)
Servo: Rear wing (DM 4.7g servo *2)
Motor: AXI2203 race
Gear:Main Gear 0.4M66T Acetal *2 (shaft3mm, 3mm ball bearing)
Spur Gear M0.4 55T, 64P8TPinionWire(4mm ball bearing)
Pinion Gear M0.4 16T
ESC:H-KING 12A Fixed Wing Brushless ESC
Battery: Lipo 3cell 450mAh G3
Control: 3CH (a motor, rear wing 2 servo)
Film of a wing: Orcon film
Aug 13, 2012, 03:21 PM
Dr Kakuta,
I'm trying to connect the fine performance of your models with the actual power(watts or amps or the flight time of your models). Have you kept notes of these?
In my opinion, your model looks best flying close to the camera, where it shows the pilot. Can you bring it close and put it into a few stable 360deg turns?
I would like to see a model of a flying horse. Maybe the rear thighs could be used as rudders and have a transparent elevator attached to its tail and thighs. A warrior rider with a drawn, horizontal bow might serve as a cannard.
George
Aug 13, 2012, 06:37 PM
K Kakuta
Kazu-kaku's Avatar
Dr Kakuta,
George
Sorry, I do not know watts or amps or the flight time of Flaptter 19-7.
New Product Not Animation: World 1st Concept Quadcopter Preview Sample(GAUI 330 FX) tycoyoken Multirotor Drone Talk 4 Jun 19, 2011 12:33 PM
Idea Using Animation in kit building lensrc Electric Plane Talk 9 Sep 11, 2006 11:27 PM
savoia in proco rosso animation Leojung Parkflyers 29 Dec 13, 2004 08:33 PM
CDROM animation in separate steps Art Newland Power Systems 15 Sep 08, 2004 12:01 AM
Yippee! Animation of Don Cleveland Launch Avenger 2 kovacsj Hand Launch 3 May 01, 2002 03:53 PM
