Jul 06, 2012, 09:25 AM
robj's Avatar
Originally Posted by -= GYRO =-
Did you buy a metric drill set?
nah...I think I went with 31/64.
frac dec mm
5/16 0.3125 7.9375
21/64 0.3281 8.3344
11/32 0.3438 8.7313
23/64 0.3594 9.1281
3/8 0.3750 9.5250
25/64 0.3906 9.9219
13/32 0.4063 10.3188
27/64 0.4219 10.7156
7/16 0.4375 11.1125
29/64 0.4531 11.5094
15/32 0.4688 11.9063
31/64 0.4844 12.3031
Jul 06, 2012, 01:03 PM
SnowDog1974's Avatar
frac dec mm
5/16 0.3125 7.9375
21/64 0.3281 8.3344
11/32 0.3438 8.7313
23/64 0.3594 9.1281
3/8 0.3750 9.5250
25/64 0.3906 9.9219
7/16 0.4375 11.1125
I have a DLE-30 so I found a 10mm drill bit. Guess a 13/32 would have worked just as well...LOL
Jul 06, 2012, 02:03 PM
gapple12's Avatar
Just picked up one of these planes with a Hacker A50-14L and Castle Ice 100 in it. The guy was running 8s (2x4s packs) in it and Ive read people prefer the 6s packs on this plane with this set up. Any thoughts before I buy batteries, prop, servos....18x8, 19x8 possibly ??........
Jul 06, 2012, 02:06 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
This may be where I got mine...it does not work, still sitting on my desk.
Hotay....didn't know for sure...
SteveT
Latest blog entry: My old shop....
Jul 06, 2012, 02:45 PM
robj's Avatar
It was worth a try, think I paid less for mine. But for more than the proce of a prop..I won't try again. I'll just drill it out. I'm usually pretty good on props...just a cleaning of bahia grass from time to time.
gapple12's Avatar
Oh, the one I got was one of the prototypes, Ive never seen this scheme. Anyone seen this one before ?
Jul 06, 2012, 02:50 PM
SteveT.'s Avatar
WOW!! Never saw one in that scheme!!!! The first one I saw was the silver, red and black one...
SteveT
Jul 06, 2012, 02:59 PM
gapple12's Avatar
SteveT
Yea, Ive looked everywhere and cant find one like it. Its in great shape, so had to buy it. Wasn't sure if 3DHS would ever get these back in stock.
Jul 06, 2012, 03:03 PM
RC Pilot / Photographer
-= GYRO =-'s Avatar
I'm pretty sure they wont have THAT color scheme in stock!
Jul 06, 2012, 03:07 PM
The RED filters through
RedTalon's Avatar
I've seen one in the Blue/Red scheme. It flew great!
Jul 06, 2012, 03:13 PM
robj's Avatar
I have, and it was probably that plane...since you are in San Antonio. Where the guy lived that had it. I got my 2 piece 71 from him.
Jul 06, 2012, 03:28 PM
Hey guys any thoughts on dx7s and throttle servo set up on my dle30 gasser- I don't have a throttle curve option, travel is set at 50% to 100% now. its flying OK now just wish it was a little
more responsive but this is my 1st gasser and don't have anything else to compare it too.
as always thx for your input.
Jul 06, 2012, 05:57 PM
gapple12's Avatar
I meant them getting ANY color in stock.
gapple12's Avatar
Small world....
Jul 06, 2012, 06:22 PM
Team 3DHS / Team JR
Bivens's Avatar
Basically, the only way to "cheat" a throttle curve....is to do it the way you USED to have to....mechanically.
I have an engineering background and it takes me back to the days where we studied angular momentum in dynamics, vectors and the like.....but here is the general idea.
FOR THE DISCUSSIONS BELOW....we'll assume full throttle must PUSH the servo rod forward....
Try to think of the motion of both the servo and the throttle arm.....as they relate to the pushrod. You can mount the servo arm so the center position is about anywhere in a 360 degree circle...Where you put this center position affects the way the ARCWISE motion of the arm translates to a LINEAR motion of the rod.
You'll have exactly the same linear motion above and below center If you center up your servo arm at 90-degrees to the rod (a 90-deg angle from the servo center screw to the rod and down the rod....).
If you push the center position further to the nose of the plane, you should notice that it starts pushing rather quickly, then slows down as it approaches the upper end (forward) travel of the servo....notice now that the upper end of the travel starts to swing the rod to the side, and not all of the angular motion is pushing forward......This is what you'd need to do to soften the top of the stick...while making the bottom more sensitive.
The opposite is true if you move the center point to the rear of 90-deg......notice that if you were to push the center way back to the rear, the first motion you'd generate would be sideways and it'd take some stick movement before you get to really moving the rod forward rapidly. THIS is the way you'd like to set it up to soften the bottom of the travel while making the top more sensitive.
Of course, each time you make an adjustment, you'd need to adjust the length of the pushrod.....and set your endpoints....because the "throttle" arm on the carb is not adjustable....full open or full closed are always in the same place...regardless of how you monkey with the servo arm.
There you have it...old-school throttle curving.....
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
Sold 3DHS 41" Edge 540 PNP $225 gonzoman5 Aircraft - Electric - Airplanes (FS/W) 10 Oct 05, 2011 10:53 AM
Wanted 3dhs Edge 540 47" (red bull scheme) DanDaMan007 Aircraft - Electric - Airplanes (FS/W) 13 Sep 29, 2011 02:19 PM
Wanted 3DHS Edge 540 47" (Red Bull Scheme) DanDaMan007 Aircraft - Electric - Airplanes (FS/W) 0 Sep 24, 2011 01:58 AM
Wanted 3dhs edge 540 47" (red bull scheme) vhuang168 Aircraft - Electric - Airplanes (FS/W) 2 Sep 08, 2011 10:13 PM
