This thread is privately moderated by vienquach, who may elect to delete unwanted replies.
Oct 27, 2011, 10:36 AM
vienquach's Avatar
Build Log
Flylite, my new "3D" plane
Rimfire 300, 28-22-1380 kv.
Electrifly 10A ESC.
Dynam 6g servos, $3.50 / two.
2s-500mah for indoor, 2s-800mah for outdoor.
Prop: 8x4 Sloflyer
AUW: 8.4oz without lipo.
Small, cheap, but flies well (no aileron) and very fun.
Flylite Night Flying, 33F, 15 mph Wind (0 min 43 sec)
Vien
Nov 05, 2011, 10:33 PM
Watt Waster
Tsavah's Avatar
FlyLite
Have the same plane and have been flying it for almost a year. It has the scares to prove it, lol.
Nov 12, 2011, 10:33 AM
vienquach's Avatar
Originally Posted by Tsavah
Have the same plane and have been flying it for almost a year. It has the scare to prove it, lol.
It has more flights than anything else I have got.
A 2s-500mah gives me close 15 min of flight time whereas the 5s-3300 only give me 8 min on the Slick 59".
Vien
Nov 28, 2011, 12:35 AM
Got the Slickness
gabrielisrael's Avatar
Looks like a great starter plane for my 7 year old!
What do you think?
Nov 28, 2011, 01:23 AM
vienquach's Avatar
What do you think?
I think so. 3 channel, easy to fly, very light and durable.
I built it for way less than $100 using parts from Hobbypartz.
Vien
Nov 28, 2011, 11:48 AM
Watt Waster
Tsavah's Avatar
FlyLite - A Starter
Looks like a great starter plane for my 7 year old! What do you think?
It can be a great starter, but you will still want a buddy box set-up since handing the Tx back and forth can be tricky during a dive. I normally use a 2s, 800-900 mAh battery pack in mine. I also had to add more than an once of nose weight to reduce the tendency to nose up if I cut power from more than half throttle. Of course you may already know this, but it is a plane for very calm days with winds below 5 mph. I tried to get away with windy day flights, but most of my battle scares are from it getting flipped over on it's back after I slowed down either on take-off or landings. I have a RimFire 300 motor in mine, but I believe a 250 is recommended and the 250 may give longer flights when the throttle is managed properly.
Latest blog entry: Center of Gravity - Airplanes
Question New to 3d Looking for a suggestion on a plane. Tony_Denver 3D Flying 5 Sep 20, 2011 07:28 PM
Discussion New HK 3D Plane: Addiction/Typhoon Hybrid? Matt Gunn Atlanta Area RC 9 Sep 20, 2011 08:29 AM
Found Trade my 3D T-Rex 250 Heli for 3D Plane omster Aircraft - Electric - Airplanes (FS/W) 0 Sep 04, 2011 09:41 PM
Discussion Making my own foam 3d plane medulla 3D Flying 1 Jun 13, 2011 07:44 AM
New method for 3D plane connect, Look my DIY 3D plane. UNIX 3D / Fun Fly Fuel Planes 4 Aug 20, 2004 10:19 AM
