Plug-in module for older Futaba FP-8SSAP Single-stick 8ch TX?
I have an older Futaba FP-8SSAP Single-stick transmitter, on 72MHz. It has a plug-in module in the side, that lets it change frequencies. I'd imagine that most such modules intended for it, are all in the 72MHz band.
Does anyone know if there is a plug-in module that will let it transmit on 2.4GHz? It has an oddball PCM-512 modulation scheme. Even among 72MHz receivers, there are only a few Futaba ever made that work with it. This oddball scheme might mean, that even if I could find a 2.4GHz module for the transmitter, there might not be any 2.4GHz receiver made that can decode the signal. I frankly don't know. You classic-radio gurus out there, can you help me out? |
Well, it has a trainer port, so you might be able to use the ppm off of that for a 2.4 module. Otherwise, you'll need a new encoder board. Might wanna check this out. http://mstar2k.com/index.php?option=...blog&Itemid=11 I know radio south converts them.
Thread Tools | |
Similar Threads | |||||
Wanted | WANTED: Futaba FP-8SSAP or HP Single Stick | stevster | Aircraft - General - Radio Equipment (FS/W) | 4 | Oct 17, 2011 10:21 PM |
Sold | 3 Futaba 8ch Single Stick PCM systems | flying4food | Aircraft - General - Radio Equipment (FS/W) | 3 | May 14, 2011 06:56 PM |
Futaba 8SSAP Single Stick System for Trade | yodarc | Aircraft - Fuel - Airplanes (FS/W) | 1 | Dec 27, 2002 06:52 PM | |
Futaba Single Stick 8SSAP complete system for trade | yodarc | Aircraft - Electric - Airplanes (FS/W) | 2 | Jul 06, 2002 06:55 PM | |
Futaba Single Stick 8SSAP complete system for trade | yodarc | Aircraft - Electric - Helis (FS/W) | 0 | Jul 05, 2002 06:13 PM |
