Aug 29, 2012, 10:42 PM
How bad is the fuse? Pics?
Aug 29, 2012, 11:15 PM
Cabledawg1's Avatar
Ive allready packed everything back in the box. The fuse isnt terrible. The damage is located on top just behind the wing bolts. Its mushy from there back allmost to the turtle deck. Just looking at the plane, you wouldnt know it was damaged....you have to touch it. Its fixable with some cloth and epoxy. There is no box damage, so it left their store this way.
Aug 31, 2012, 09:03 PM
Tom and Skyjet,
Could you tell me where and how you mounted your GoPro cameras. I'm thinking of buying one for my 110 but I have a Saito 125 in mine and don't want to end up with "slimy" pictures.
I know....go electric and you don't have to worry about that!!
Thanks for your help
Aug 31, 2012, 11:02 PM
KJ4YNM
RCPtero's Avatar
Originally Posted by Oiler747
Tom and Skyjet,
I tarted with a mount on top of the fuse centered right in front of the wing. Decided the fuse blocks too much of the ground facing back and don't like the prop effects facing forward. So I stuck a second mount directly on the landing gear where it's bolted to the fuse.
Tom
Aug 31, 2012, 11:17 PM
Thanks for the reply Tom
Did you use the sticky mounts that came with the GoPro and are they secure enough??
Sam
Sep 01, 2012, 07:20 AM
KJ4YNM
RCPtero's Avatar
Sam
Yes direct on the LG, just clean it with alcohol first. If on the covering, clean with alcohol, prick the rea with a pin a few times, then apply some thin CA to really adhear the covering to the balsa, then apply the mount.
I started using the lanyard fastened to strut. No I dont bother with the lanyard at all.
Tom
Sep 01, 2012, 07:41 AM
Electric or Bust!
skyjet's Avatar
Tom
Ditto
Sep 01, 2012, 11:24 AM
Electric or Bust!
skyjet's Avatar
Tom and Skyjet,
With the Saito, you might consider mounting it under one of the wings just outside of the wing strut.
Sep 11, 2012, 08:13 AM
First test flights with my Rascal 110 using a Syssa 180HP, Spektrum servos, 14.25 pounds dry.
Yes, it was a bit on the windy side...
SIG Rascal 110 Test Flight (4 min 16 sec)
Sep 11, 2012, 03:35 PM
Electric or Bust!
skyjet's Avatar
Originally Posted by pettit
First test flights with my Rascal 110 using a Syssa 180HP, Spektrum servos, 17.5 pounds RTF.
http://www.youtube.com/watch?v=UIm6S...1&feature=plcp
The "180HP" had me confused until I found out 180HP is the SKU # for the Syssa 30.
Nice flying on such a windy day!!!
Sep 11, 2012, 03:54 PM
*It Ain't Lookin Good*
olezippi's Avatar
17.5 pounds ???
Sep 11, 2012, 06:53 PM
Electric or Bust!
skyjet's Avatar
Originally Posted by olezippi
17.5 pounds ???
Why ???
Sep 12, 2012, 06:14 AM
olezippi's Avatar
Originally Posted by skyjet
Why ???
Unless pettit is running a lot of extra equipment or an electric set which he's not, the Rascal should have came in around 12-12 1/2 lbs.
Sep 12, 2012, 09:12 AM
Rascal 110
Yep, that does sound rather heavy.
I think that's a typo on my part, but just to be sure, I'll weigh it again tonight.
Sep 12, 2012, 12:16 PM
Electric or Bust!
skyjet's Avatar
It did sound heavy to me too. My first rascal had a G26 and a 20 once fuel tank and weighed 15 1/2lbs RTF. No flaps though.
For Sale Sig Rascal 110 g wheeler Aircraft - Fuel - Airplanes (FS/W) 1 May 29, 2012 03:05 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Airplanes (FS/W) 3 Sep 18, 2011 08:49 PM
For Sale Sig Rascal 110 g wheeler Aircraft - Electric - Power Systems (FS/W) 3 Sep 05, 2011 08:55 PM
Sold Sig rascal 110 red/white lpu yates55 Aircraft - Fuel - Airplanes (FS/W) 10 Apr 15, 2011 06:06 PM
Sold Sig rascal 110 red/white lpu yates55 Aircraft - Electric - Airplanes (FS/W) 14 Apr 15, 2011 06:05 PM
