look what i found,
vertical stabs swept and moved back this will definatly help yaw instablility. the kanards up front look like decoration but would help with moving cg forward getting a bigger battery up front. not to my fancy though. |
I had it twice. The first time I recovered I'm not sure what I did, but I do know that the throttle was off. The second time I almost recovered but was a bit too late. The damage was only a wrinkled nose.
good news
acourding to what i have read on here the cg is just in front of the finger holes. if this is the case then the new radjet balances very well with a 2200mah 3s battery in it. i did move the vstabs back but there so lite i dont think this would change much from stock as far as the cg is concerned. |
The New pink Radjet comes with 5 mm cabon tube spar!
Just bought one. Awaiting maiden
So what's the trick to making the stickers stay stickered?
I have used a layer of PVC on the edges, just smeared on - so far so good.
On my composite ARF's I have used dabs of CA to hold down edges of covering. Would love to know if anyone has better solution. |
Did you fly it with 2200mah pac
Thread Tools | |
Similar Threads | |||||
Discussion | Hobby King Kinetic 800 slope soarer | Conwy-Soarer | Slope Soaring | 16 | Apr 15, 2012 12:53 PM |
Rave | Hobby King Kinetic 800 | gazza2003au | Australia | 23 | Aug 29, 2011 09:25 AM |
Discussion | A beat up old Hobby King L-39 Albatross 'Brietling' jet | Fliegenmong | Aerial Photography | 0 | Aug 07, 2011 06:24 AM |
Alert | hobby king make magic hobby king just wash their dirty hand | presa1200 | HobbyKing | 71 | Jul 21, 2011 08:45 AM |
Sold | Prop only for Hobby King Kinetic 800 | FNFAL | Aircraft - Sailplanes (FS/W) | 1 | Jul 19, 2011 07:01 PM |
