Oct 13, 2011, 09:13 AM
ServoCity's Avatar
Link
Servo Mounting Hardware (Grommets, Eyelets, Screws, Mounts, Tape)
We have everything you need when it comes to mounting servos - and at great prices too!
Mounting Eyelets
We offer three (3) sizes of eyelets. Eyelets 803 and 809 work with mini and standard size servos.
Eyelets 810 work with 1/4-scale servos.
#803 - $1.35/12 pack
Length: .20 (5.3mm)
Bore: .10 (2.6mm)
#809 - $1.35/12 pack
Length: .23 (5.9mm)
Bore: .10 (2.6mm)
#810 - $1.35/12 pack
Length: .29 (7.2mm)
Bore: .10 (2.6mm)
Rubber Grommets
When should I use grommets?
Grommets should be used with your servos when vibration is present.
They will help protect the electronics during normal operation and also in an unfortunate crash.
In industrial applications when accuracy is crucial, especially when the servo in under load, we recommend not using grommets.
G902 - $1.35/12 pack
This grommet is designed to work with all standard size Futaba servos that have open end mounting holes.
G904 - $1.35/12 pack
These also work with Hitec mini and standard size servos.
G910 - $1.35/12 pack
For Futaba standard size servos with the closed hole mounting tabs 910 grommets need to be used.
G916 - $1.35/12 pack
G918 - $1.35/12 pack
G920 - $1.35/12 pack
Grommets 916, 918 and 920 are designed for both Hitec and Futaba 1/4 scale servos.
Servo Mounting Screws
#801 - $1.35/12 pack
Length: .575
Screw Diameter: .087
Head Diameter: .235
#93406A108 - $0.12 each
Length: .375
Screw Diameter: .112
Head Diameter: .250
(These screws are NOT designed for use with eyelets or grommets)
Servo Mounting Tape
BUKQ4135 - $2.45
1/2" Wide
BUKQ4136 - $2.95
1" Wide
Servo Mounts
FEATURED: New Vertical Aluminum Servo Mounts- $6.99
Brand new and exclusive to ServoCity, this Vertical Aluminum Mount is perfect for nearly any servo mounting application.
Includes (4) 6-32 x 1/4 Pan Head Phillips Screws.
Designed for standard size Hitec and Futaba servos.
Click here for our entire selection of servo mounts...
FOR ALL SERVO MOUNTING HARDWARE, CLICK HERE!
Sold #2 x 9/16" Socket Head Servo Mounting Screws 100pk miller6196 Aircraft - General - Miscellaneous (FS/W) 1 Aug 24, 2011 06:53 PM
Found #2 x 9/16" Socket Head Servo Mounting Screws 100pk- $9 w/S&H Plasmajoe Aircraft - General - Miscellaneous (FS/W) 0 Aug 24, 2011 06:41 PM
Sold New- Hitec 5645 digital servo(missing grommets & screws) $20.00 shipped 540RCflyer Aircraft - General - Radio Equipment (FS/W) 1 Dec 28, 2009 09:41 PM
Question Anyone know the part # of the hardware bag with servo mounts? Sky_Dancer Mini Helis 3 May 23, 2009 11:20 PM
Wanted Futabe servo mounts, screws. and Servo Arms (alum if possible) stevela Aircraft - General - Miscellaneous (FS/W) 0 Sep 29, 2006 06:25 PM
